Angular Acceleration of a Rod in an Uneven String Setup
12 replies · 3K views · last reply
Vibhor
Note : In the above setup the string lengths are unequal and the left angle is 30° and right angle is 60° .
[/B]
Just after the string is cut , writing force eq. for rod in vertical direction .
##Mg - Tcos60° = Ma_y ## (1)
Writing force eq in horizontal direction
##Tsin60° = Ma_x## (2)
Writing torque eq about the CM of the rod ,
##Tcos 60°\frac{L}{2} = \frac{ML^2}{12} \alpha ## (3)Writing constraint eq. for the left end point of the rod where string is attached ,the component of acceleration of left end along the string length should be zero .
##a_ycos60° - \frac{αL}{2}cos60° - a_xcos30°= 0 ## (4)Solving the above four eqs .give ##T= \frac{2}{7}Mg##
and ##\alpha = \frac{6g}{7L}##
Could someone check my work ?
According to official answer key , T=Mg/2 and α = 3g/2L :oldeyes: .
Do you mind rechecking the constraint equation ?
Is there some sign error ?
Now consider a modified setup .
The same four equations in this case would be
##Mg - Tsin2\theta = Ma_y##
##Tcos 2\theta = Ma_x ##
##Tsin \theta \frac{L}{2} = \frac{ML^2}{12}\alpha##
##a_y cos(90°-2\theta) - \frac{\alpha L}{2}cos(90°- \theta) - a_x cos2\theta = 0 ##
Please check the above equations .
I rechecked my calculations but the result is same as the one in OP .
The answer key doesn't have too many mistakes .
I also agree with the answer in the OP.
One way to get their answer is to replace the correct constraint equation with the incorrect equation ##a_y = \alpha L/2## (as though the rod is instantaneously rotating about a fixed left end).
Or in the case when both the strings are vertical .
Do you think my equations for the set up in post 4 are correct ?
Yes, a vertical string would give a constraint of ##a_y = \alpha L/2##. But then, I think you would get T = Mg/4.
Yes, they look correct to me.
Yes .
Thank you very much .
Thanks @haruspex
Please see the attached image .
Just after the right string is cut , the net acceleration of the CM of the rod is vertically downwards .Hence rod must move such that CM falls straight down.The left end must also fall straight down .
But net acceleration of the left end point will be towards left ,which means the next instant after right string snaps , it moves towards left .
Aren't the movement of CM and left end contradicting each other .
I am sure I am messing somewhere .
Why? There will be an angular acceleration.
Right . So the next instant , rod moves such that CM moves straight down and the left end moves leftwards ?
Yes.
