Angular Moment Operator Vector Identity Question
8 replies · 3K views · last reply
Chronum
In my EM class, this vector identity for the angular momentum operator (without the ##i##) was stated without proof. Is there anywhere I can look to to actually find a good example/proof on how this works? This is in spherical coordinates, and I can't seem to find this vector identity anywhere. I've tried Googling for hours now, and I've legitimately come up with no example with a good accompanying explanation, of how this particular identity is working. This is the identity in question. Any help would be appreciated.
(\vec{r}\times\nabla)\psi =
\nabla\times \vec{r}\psi - \psi(\nabla\times \vec{r})
EDIT: I've also seen this identity on Wikipedia, which _may_ satisfy my requirement if I'm thinking of the curl operator right.​
##\nabla \times(\psi \vec{r}) = \psi(\nabla \times \vec{r}) + \nabla\psi\times\vec{r}##
For the first term on the RHS, we can use the anticommutativity of the cross product, and state​
##\psi(\nabla \times \vec{r}) = - \psi (\vec{r} \times \nabla)##
and then the identity becomes a trivial moving around of terms. Am I thinking about that in the right way?​
It shouldn't be that hard to show using product rule of derivative but for some reason I got the sign reversed.
(\mathbf r \times \nabla)_i \psi = \epsilon_{ijk}r_j\partial_k \psi
but ##r_j\partial_k \psi = \partial_k (r_j \psi) - \psi \partial_k r_j##. Hence
(\mathbf r \times \nabla)_i \psi = \epsilon_{ijk}(\partial_k (r_j \psi) - \psi \partial_k r_j) = -\epsilon_{ikj}\partial_k (r_j \psi) + \epsilon_{ikj}\psi \partial_k r_j = -(\nabla\times\mathbf r \psi)_i + \psi(\nabla \times \mathbf r)_i
Still trying to figure out where I went wrong.
EDIT: The above is correct.
Thank you so much. I've never really been introduced the inner nitty gritties of the vector calculus identites/their sources, so this tells me I should probably acquaint myself better with them.
It looks like you got this identity not correct:
whereas mine is, check https://en.wikipedia.org/wiki/Vector_calculus_identities#Curl_2
ψ(∇×⃗r)=−ψ(⃗r×∇)\psi(\nabla \times \vec{r}) = - \psi (\vec{r} \times \nabla)
No, that's incorrect. The LHS is a vector but the RHS is a vector operator. While curl operation and vector cross product share many properties, their anticommutativity property is different.
I think you're right and the OP is wrong.
Yes, just confirmed it from the Wikipedia link I shared above.
Yes, just saw it.
@Chronum there are no shortcuts with this sort of identity. You just have to work through each component.
I tend to use the determinant form of the cross product and just do the first component. The others generally follow by the cyclic symmetry.
PeroK said:
Yes, just saw it.
Maybe this is also complicated by the fact that I'm trying to do this in spherical coordinates, when I can potentially do it in cartesian. I'm uploading a snippet of the notes I'm looking at, just making sure I'm not misinterpreting anything. The given relation holds true without the extra term because we're dealing with a radial vector here.
  • Handwritten line reading "Since (r x ∇)ψ = ∇ x (r ψ)", a vector identity relating the angular momentum operator to a curl.
If ##\mathbf r## is a position vector (you call it radial vector) then yes the relation in your note is correct after multiplication with -1 in either sides of the equation. Have you checked the wiki link in post#4?
Why not trying what Perok suggested in post #7 by verifying the first component, e.g. the x-component?
Moreover, the first relation (the corrected version) you posted in post #1 holds for any vector field ##\mathbf r## and scalar field ##\psi## regardless of the coordinate system.
