Angular momentum and Quantum Number l
9 replies · 2K views
krawls30
Move here from another forum, so no homework template.
The question: Consider two masses of 0.1 gm each, connected by a rigid rod of length 0.5 cm, rotating about their center of mass with an angular frequency of 800 rad/s. a.) What is the value of l corresponding to this situation? b.) What is the energy difference between adjacent l-values for the l you have just calculated?
Relevant equations:
Moment of Intertia about center of mass = ∑miri
L=I * ω
L= ħ[l(l+1)]1/2
My attempt at part a of the problem:
r= 0.0025m
mass= 0.0001 kg
I = 2 * (0.0001 kg) * (0.0025 m2) = 1.25 * 10-9 kg m2
L = 1.25 * 10-9 kg m2 * 800 rad/s
L/ħ = 9.48*1027 = [l(l+1)]1/2
Which this is the answer, but when I solve for l(the quantum number for angular momentum) I get a number with order of magnitude of 1055 am I completely overlooking something here? I can't think of any other ways to solve this problem. Thank you in advance for your help!
Are you sure this is correct?
I think so... I used this website http://socratic.org/questions/how-do-you-find-moment-of-inertia-of-two-point-masses
Look again, that gives the another formula than what you wrote
Well I also tried 1/12 ML2 but that still isn't working.
No you have to square the radius. I = mr^2, not mr.
I don;t see that on the page
OH that's my mistake, that was a typo it's supposed to be Σmiri2
If you don't know the mass of the ord you can't use the second equation because M is the mass of the rod
it's a rigid body.. so the mass of the rod is being ignored
