Angular Position, Velocity, and Accelration.
The discussion revolves around calculating the angular position, speed, and acceleration of a swinging door described by the equation θ = 5.00 + 10.0t + 2.00t². At t = 0, the angular position is 5.00 radians, but the initial angular speed calculation leads to confusion due to division by zero. The correct approach involves using calculus to differentiate the position function, resulting in ω = 10.0 radians per second at t = 0. The importance of understanding derivatives in this context is emphasized, highlighting the necessity of calculus for solving such problems. The conversation ultimately clarifies the method for determining angular motion parameters.
bolivartech
During a certain period of time, the angular position of a swinging door is described by θ = 5.00 + 10.0t + 2.00t2, where θ is in radians and t is in seconds. Determine the angular position, angular speed, and angular acceleration of the door (a) at t = 0 and (b) at t = 3.00 s.
ω = dθ / dt
α = dω / dt
a) θ = 5.00
ω = 5 / 0
α = dω / 0
This just doesn't make sense, you cannot divide by 0.
But the other formulas, have either both ω and α or t cancels everything out.
This is supposed to be a simple problem of instantaneous angular speed and acceleration, how am I over complicating this?
The expressions dθ/dt and dω/dt are not fractions. They are derivatives. Have you studied calculus? Do you know what differentiation is (the process of taking a derivative)? I'm asking because your attempted solution suggests that you don't.
d/dt is a symbol which, when applied to function, means, "take the derivative of that function with respect to time."
In this case, the function is θ (or θ(t), to show the argument explicitly), and we write:
dθ/dt = d/dt (5.00 + 10.0t + 2.00t2 )
Now, knowing how to actually calculate the derivative of this function of time requires knowing differential calculus.
Thanks, I don't know why I didn't see that... I stayed up way to late working on homework I actually enjoy doing.
ω = dθ/dt = d/dt (5.00 + 10.0t + 2.00t2 ) = 10
10K
