Angular Speed Between 2 rims attached by a belt
dimmermanj
So I'm new to the Physics Forums and am looking for some help on this problem:
Wheel A of radius r=10cm is coupled by belt B to wheel C with radius R=25cm.
the angular speed of wheel A is increased from rest at a constant rate of 1.6 rad/s^2.
Find the time needed for wheel C to reach an angular speed of 100 rev/min, assuming the belt does not slip (hint: the linear speeds of the two rims must be equal)
my original process of solving was to try and relate the two speeds with a ratio, but that method has proven unsuccessful.
I get really confused whenever dealing with angular speed so if anyone could help that'd be great!
thanks
Jim
Ok using your method if
[tex]\frac{\omega_B}{\omega_C} = \frac{R_C}{R_B}[/tex]
when ωC is 100 rpm what is ωB ?
Then you know that
[tex]\alpha = \frac{\omega_2 - \omega_1}{t}[/tex]
