Graduate Annihilation creation operators in case of half H.oscillator
The discussion revolves around verifying the Ehrenfest theorem for a wave function of a half harmonic oscillator, specifically |Y>=(1/sqrt(2))*(|1>+|3>). The calculations using annihilation and creation operators yield a result that violates the theorem, raising questions about the validity of these operators in this context. It is noted that the standard operators for a full harmonic oscillator do not exist for the half oscillator, and alternative operators A and A† are proposed. The conversation highlights the importance of boundary conditions, suggesting that Neumann conditions may be more appropriate than Dirichlet ones for this scenario. Ultimately, the participants agree that while Ehrenfest's theorem remains valid, its application in this case requires careful consideration and potentially different methods, such as using Hermite polynomials or the Heisenberg picture.
SUVAM ROY
I'm trying to check if Ehrenfest theorem is satisfied for this wave function,
|Y>=(1/sqrt(2))*(|1>+|3>),
where |1> and |3> are the ground and 1st exited state wave functions of a half harmonic oscillator. When I'm calculating the expectation values of x and p using annihilation creation operators and trying to check the Ehrenfest theorem I'm getting
m*(time derivative of <x>)=2*<p>
which violates the Ehrenfest theorem. So, my question is whether annihilation creation operators are valid in case of a half harmonic oscillator.
If ##a## and ##a^{\dagger}## are destruction and creation operators for the full harmonic oscillator, then the destruction and creation operators for the half harmonic oscillator are
$$A=aa$$
$$A^{\dagger}=a^{\dagger}a^{\dagger}$$
The operators ##a## and ##a^{\dagger}## are not defined (do not exist) in the space of states of the half harmonic oscillator.
Likes SUVAM ROY
What is this?
A. Neumaier said:
What is this?
Come on ! you can google it too !
There are two natural boundary conditions one can place at ##x=0##. It is odd that http://www.physicspages.com/2012/08/18/half-harmonic-oscillator/ only describes the odd half with Dirichlet boundary conditions; the even half with Neumann boundary conditions is not even mentioned.
Likes dextercioby
$$A=aa$$
Thanks a lot.
This is the standard practice in QM (see e.g. a textbook treatment of infinite well potential) to require that ##\psi## (not ##\psi'##) vanishes at the points where the potential ##V## is infinite. The textbooks also give a physical reason for that. I has to do with the fact energy should be finite and that Schrödinger equation has ##\psi## (and ##\psi''##) but not ##\psi'##.
More generally, Neumann boundary conditions in physics usually correspond to ends that can oscillate freely. It should be intuitively clear that ends at infinite ##V## are far from being "free". Think, e.g., of a guitar string.
$$A=aa$$
Sorry, but I'm still getting the same $$2<p>$$result when I replaced ##a## and ##a^{\dagger}## by ##A## and ##A^{\dagger}## in expression for x and p and did the calculations. Why this "2" is coming in the expression? Is Ehrenfest theorem also not defined in this case?
I did not say that such a replacement is legitimate. You should not express ##x## and ##p## in terms of creation/destruction operators. Ehrenfest theorem is still valid, but it is more subtle.
So, I have to take the Hermite polynomials and calculate expectation values in integration method? Or, is there any other easier method to do this? So that I can verify Ehrenfest theorem.
The approach with the Heisenberg picture should be the easiest. The direct calculation with Hermite polynomials should work too, but make sure to first renormalize them because now they are defined only for x>0.
I'll try that. Thanks again.
Hello everyone :biggrin:
As I'm starting to study exactly the topic of the half oscillator for my PhD research, may I post my future replies/ideas/considerations here or would you rather have me start a brand new thread?
Thanks and have a nice day!
Frank
p.s.: the retro smileys! :headbang::oldbiggrin::oldmad::oldruck:
Hm, I'd rather start a new thread.
Likes jim mcnamara
Please start a new thread.
