Determining k and g from a Straight Line Plot for a Bar Pendulum
  • Thread starter Thread starter maverick280857
    Pendulum
The discussion focuses on determining the values of g (acceleration due to gravity) and k (radius of gyration) for a bar pendulum using a straight line plot. The time period T of a bar pendulum is expressed as T = 2π√(I/Mgd), where I is the moment of inertia. The moment of inertia is defined as I = I₀ + Md², with I₀ = Mk² for a perfect rod. The relationship between d and k is established through the equations d₁ + d₂ = (4π²(d₁ + d₂)/T²) and d₁d₂ = k², indicating that a specific straight line plot can yield the values of k and g.
  • Understanding of pendulum mechanics and time period calculations
  • Familiarity with moment of inertia concepts
  • Knowledge of straight line graph analysis
  • Basic algebra for solving equations
  • Study the derivation of the time period formula for bar pendulums
  • Learn about the relationship between moment of inertia and radius of gyration
  • Explore graphical methods for determining physical constants from experimental data
  • Investigate the effects of varying mass and length on pendulum dynamics
Physics students, educators, and researchers interested in pendulum dynamics and experimental physics methodologies.
maverick280857
How can one determine from a straight line plot, the value of g (acceleration due to gravity) and k (radius of gyration) of a bar pendulum?
The time period of a bar pendulum is given by
T = 2\pi\sqrt{\frac{I}{Mgd}}
I = I_{0} + Md^2
where I is the moment of inertia about an axis passing through the pivot, d is the distance between the center of mass and the pivot, M is the mass of the rod.
In an experimental setup, we are varying d and measuring T for every chosen d.
Also,
I_{0} = Mk^2
So,
I = M(k^2 + d^2)
Hence,
T = 2\pi\sqrt{\frac{k^2 + d^2}{gd}}
For a fixed value of T, there are two values of d, and
d_{1} + d_{2} = \frac{4\pi^2(d_{1} + d_{2})}{T^2}
and
d_{1}d_{2} = k^2
But which straight line plot yields k and g? I can see that if k >> d, then we can say that T^2 is proportional to 1/d, but this would be a gross approximation, valid only for points very close to the center of mass.
Thanks
Cheers
vivek
Moment of inertia around a center of mass for perfect rod of length 2k is:
I_{0}=\frac{1}{12}m(2k)^2
How did you got this equation:
Fixed walue of T? What two walues of d?
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 21 ·
