SpaceTiger said:
I thought we had agreed it
did still suffer this problem:
https://www.physicsforums.com/showthread.php?t=82628&page=2"
Your theory makes a small cosmological constant more "natural" (removing the cosmic coincidence problem), but does not resolve the discrepancy between particle physics and gravitational theory that leads to the huge number discussed above (the Lambda problem).
Thank you for your comment ST.
Actually, we agreed that SCC does have DE, but as I maintain it is not
unknown DE, rather that observed in the laboratory as the Casimir force.
This prediction of the theory can be tested (and falsified) by an experiment to look for a rounding off of the maximum Casimir force in low gravitational fields, away from the Sun and major planets, in the outer solar system.
The problem with GR is that it makes no prediction of false vacuum density. The degree of freedom provided by the cosmological constant allows vacuum to have an energy density but it makes no prediction of what that might be. The only indication that it might be non zero is the requirement of the standard [itex]\Lambda[/itex]CDM model to have ~ 73% (by density) DE.
The problem with QT is that the virtual energy density spectrum is cut off only by the Planck scale, hence the false vacuum provides a potentially very large and dense QFE source.
Unfortunately for the theory, (but fortunately for us!), the gravitational curvature associated with this quantum vacuum density is only observed, if at all, as the cosmological DE at 10
-121 less than that theory predicts.
On the other hand in SCC there is a natural and moderate cut-off provided by its two field equations, i.e. the gravitational and scalar field, which require a small false vacuum density for mutual consistency.
In flat space-time the two solutions are consistent, but the introduction of increasing curvature gradually separates the two solutions and requires a small false vacuum density. This would be made up of contributions of zero-point energy from every quantum matter field which has a natural re-normalised ‘cut-off’ E
max determined, and therefore limited, by those solutions.
The 'Casimir' electro-magnetic vacuum field energy is predicted by SCC to have a density in the near Earth gravitational field of:
[itex]\rho[/itex]
qv ~ -2.4 x 10
-9 gm.cm
-3.
Garth
