Does Travel Distance Affect Aging in the Twin Paradox?
  • Context: Graduate
  • Thread starter Thread starter kahoomann
    Paradox Twin paradox
The discussion centers on the Twin Paradox, specifically addressing the effects of travel distance and acceleration on aging. It concludes that the twin who travels a longer distance (L) ages less than the twin who travels a shorter distance (L/2) due to the differences in their world-lines and the time spent at high velocity. Acceleration does not cause time dilation directly; rather, it breaks the symmetry between the twins' experiences. The key factor is the proper length of their world-lines, which determines their respective aging rates upon reunion.
  • Understanding of the Twin Paradox in special relativity
  • Familiarity with concepts of world-lines and proper time
  • Knowledge of time dilation and its mathematical formulation
  • Basic grasp of inertial and non-inertial reference frames
  • Study the implications of the spacetime interval in special relativity
  • Explore the effects of gravitational potential on time dilation
  • Investigate the role of acceleration in non-inertial reference frames
  • Learn about the Coriolis and centrifugal forces as analogues in relativity
Physicists, students of relativity, and anyone interested in the nuances of time dilation and the Twin Paradox will benefit from this discussion.
kahoomann
Suppose one twin travel to a distance L and turn around, another twin travel to a distance L/2 and turn around. When they reunite at home, the twin travel longer will age less?
Since they both experience acceleration, so acceleration is not the cause of age difference.
Can acceleration break the symmetry in this case? If not, what breaks the symmetry?
The amount they age is determined by the proper length of their individual world-lines. The longer time you spend at higher velocity, the shorter your world-line is. The first twin spends more time at high speed relative to the two common points in their world-lines than the second twin does, and so ages less.
what symmetry? Is there any inertial reference frame where their worldlines are symmetric?
The symmetry is this. If twin A measure twin B clock to run slowly, simply because B has a speed v relative to A, then the principle of relativity implies that B will also measure A's clock to run slowly, since the speed of A relative to B is also v. The question is what breaks this symmetry?
kahoomann said:
The symmetry is if twin A measure twin B clock to run slowly, simply because B has a speed v relative to A, then the principle of relativity implies that B will also measure A's clock to run slowly, since the speed of A relative to B is also v
And it has the same resolution as in the original twin paradox -- the only difference is that in this case, you've had both twins make an invalid argument.
(In the usual twin paradox, this argument is actually correct for one of them)
Why both twins make an invalid argument?
Do you mean that principle of relativity is invalid in this case?
You aren't invoking the 'principle of relativity'. You are trying to invoke the time dilation formula in some coordinate chart (that you haven't explicitly defined), and ignored the fact that your coordinate chart isn't inertial, so time dilation isn't the only relevant effect. i.e. you've made exactly the same mistake as the one in the usual twin paradox.
>>So time dilation isn't the only relevant effect.
What else is the relevant effect?
Familiar examples of this phenomenon should be the Coriolis force and centrifugal force. In special relativity, there are temporal analogues. For example, in the most 'natural' way to attach a comoving coordinate chart to an accelerating observer, you have the effect that when he accelerates towards a clock, it is observed to run faster. (The increase is proportional to coordinate distance, and probably also to the magnitude of the acceleration) And similarly, when accelerating away from a clock, it is observed to run slower, or even backwards.
Since you haven't actually specified which coordinate chart you're using, I couldn't say what actual effects would be seen.
I don't think "accelerating observer" is the problem. since they both experience acceleration during flight, they can stop their clocks before engine ignition and restart their clocks after cutoff. So the clocks would show the total proper times they were in inertial motion.
So it must be something else that cause the age difference.
You didn't read Hurkyl's post closely enough. The acceleration doesn't effect how "their" clock runs, but instead what they determine is happening to the other twin's clock. Stopping their own clock during their own acceleration has no effect on their observation of what is happening to the other's clock. And remember, as Hurkyl pointed out in his post, this observation depends on the distance between the twins during the acceleration. The asymmetry comes in when one twin travels a shorter distance before turning around, thus he will measure a different distance between himself and his twin at this point than his twin will when he turns around.
As DaleSpam indicated in another thread that acceleration does not cause time dilation by itself.
DaleSpam said:
My recommendation is to forget the acceleration. It only serves to break the symmetry and does not cause time dilation by itself. Instead, use the spacetime interval which allows you to extend the analysis to arbitrarily accelerating twins.
This is just gravitational time dilation. Actually, it is Not the g-force/acceleration that cause time dilation, it is the gravitational potential that causes time dilation
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 85 ·
  • · Replies 24 ·
  • · Replies 24 ·
  • · Replies 44 ·
  • · Replies 21 ·
