Estimating Dissolving Solid Weight Change
  • Thread starter Thread starter Weave
    Linear
The discussion revolves around estimating the weight change of a dissolving solid in water using the formula f'(t) = -4 f(t)(5 + f(t)). At time t = 2, with 2 grams of solid, the derivative f'(2) is calculated to be -56 grams/minute. To estimate the weight one second later, the change in mass is computed as -56 grams/minute multiplied by 1/60 minute, resulting in a loss of approximately 0.93 grams. Participants note that using a linear approximation for such a large time interval may not be accurate, but the context of the problem allows for this estimation. Ultimately, the accuracy of the approximation depends on the behavior of the function f.
Weave
Let f(t) be the weight (in grams) of a solid sitting in a beaker of water. Suppose that the solid dissolves in such a way that the rate of change (in grams/minute) of the weight of the solid at any time t can be determined from the weight using the forumula:
f'(t) = -4 f(t) ( 5 + f(t) )
If there is 2 grams of solid at time t = 2 estimate the amount of solid 1 second later.
So I get f'(2)=-56 Not sure what to do after that, do I use a differential?
Do you know what linear approximations work?
Using the derivative of the function which gives the amount of solid, find the gradient of the tangent at the point you know the functions value.
You have the gradient, and a point this straight line passes though. Find the equation of this new line, and sub in the value of one second later.
Yes, the whole point is to use the differential.
If f '= H(f,t), then df= H(f,t)dt and, of course, the "next" value of f is f+ df.
In particular, if f '(2)= -56, then df= -56 dt. What is dt here?
(I don't think a linear approximation is going to be very accurate for this large a dt!)
dt=1 second? so we still get -56? That doesn't seem right
They say that f' is in grams per minute. So The change in mass will be -56 grams/minute * 1/60 minute, so a bit less than one gram is lost. It is *still* strange to use a differential for such a large time interval, it would really make sense only for a delta t at least ten times smaller. Oh, well...
Patrick
That's a very subjective call. It might well be an extremely accurate approximation - depends on f, not what units of time you use.
True. When I said "I don't think a linear approximation is going to be very accurate for this large a dt!" I hadn't noticed that the problem gave df/dt in grams per minute (so t= 2 minutes but then asks for the value in one more second (so dt= 1/60, not 1). However, I had cleverly asked "what is dt here" so no one would notice!
  • · Replies 20 ·
