Another Merry Go Round Question
  • Thread starter Thread starter MJC8719
The discussion centers on calculating the initial and final kinetic energies of a system involving a disk-shaped merry-go-round with a radius of 2.63 m and mass of 155 kg, rotating at an angular speed of 0.615 revolutions per second. A 59.4 kg person running at 3.99 m/s jumps onto the rim of the merry-go-round. The user correctly identifies that the initial kinetic energy (Ki) should be the sum of the kinetic energies of both the person and the merry-go-round, but struggles with the final kinetic energy (Kf) calculation, indicating a need to incorporate angular momentum principles and correct unit conversions for angular speed.
  • Understanding of kinetic energy formulas: KE = 0.5mv² and KE = 0.5Iω²
  • Knowledge of angular momentum and its conservation
  • Familiarity with unit conversions, particularly between revolutions per second and radians per second
  • Basic physics concepts related to rotational motion
  • Review the principles of angular momentum conservation in rotational systems
  • Learn how to convert angular speed from revolutions per second to radians per second
  • Study examples of kinetic energy calculations involving both linear and rotational motion
  • Explore the relationship between linear velocity and angular velocity in rotating systems
Physics students, educators, and anyone interested in understanding the dynamics of rotating systems, particularly in the context of kinetic energy calculations and angular momentum.
MJC8719
A disk-shaped merry-go-round of radius 2.63 m and mass 155 kg rotates freely with an angular speed of 0.615 rev/s. A 59.4 kg person running tangential to the rim of the merry-go-round at 3.99 m/s jumps onto its rim and holds on. Before jumping on the merry-go-round, the person was moving in the same direction as the merry-go-round's rim.
(b) Calculate the initial and final kinetic energies for this system.
Ki =
Kf =
So I am stuck on Kf, but for Ki i thought it should just be the sum of the kinetic energy of the man plus the kinetic energy of the disk
I set up my equation like this:
0.5mv^2(KE of person) + 0.5Iw^2(KE of disk) =
0.5(59.4)(3.99^2) + (0.5)(0.5(155)(2.63^2))(0.615^2)
I solved for this and did not get the correct answer which means I have probably set up the equation wrong...can anyone help me out with this?
not sure if this is correct or not but i think you have to use angular momentum and then combine it with the energy formula. and solve for the unknown. so u have to use two equations on this one. what's the answer ur suppose to get?
Again, use correct units for angular speed: radians/sec.
  • · Replies 44 ·
