Answer Root-Mean-Square Fluctuation in Box of Length L
11 replies · 2K views
terp.asessed
There is an equal probability density for finding a particle anywhere in the box. Assume that the box is of length L.
What would the root-mean-square fluctation in position be?
root-mean-square fluctation2 = <x2> - <x>2
since there is an equal probability density anywhere in the box, I assumed normalization:
1 = integral (x=0 to L) p(x)dx = integral (x=0 to L) C dx
1 = C integral (x=0 to L) dx = CL
C = 1/L
probability density = p(x) = 1/L
So...from here, I got:
<x> = integral (x=0 to L) p(x) x p(x) dx = 1/L2 integral (x=0 to L) x dx = 1/2
<x2> = integral (x=0 to L) p(x) x2 p(x) dx = 1/L2 integral (x=0 to L) x2 dx = 1/2 = L/3
therefore:
root-mean-square fluctation2 = <x2> - <x>2 = L/3 - 1/2...which does not make sense at ALL--could someone point out the error I've made? I have no idea where I made a mistake because I believe the solution to be something like of one value, like 3/12 or something, not what I got...
It is ##\langle x\rangle^2##, not ##\langle x\rangle## ... Also, either your normalisation is wrong or your expectation values are. You have to decide whether p(x) is the probability density or the wave-function. You have used it as the probability density when normalising but as a wave function when computing the expectation values. This results in very strange units on your resulting expectation values.
root-mean-square fluctation2 = <x2> - <x>2 = L/3 - 1/4.
And, honestly, I am using p(x) as probability density--hence normalization...teacher hinted that the problem is NOT a wave...just a matter of probability density and expectation values...
Then your computations of the expectation values are wrong as you are including ##p(x)^2##. The expectation value of ##f(x)## should be
\langle f(x) \rangle = \int_0^L f(x) p(x) dx.
Ok, wait--what is exactly f(x)? if p(x) is a probability density?
##f(x)## is a function of ##x## that you want to know the expectation value of. In your case ##f(x) = x## and ##x^2##, respectively.
wait, so, to make a loooooong story short:
<x> = integral (x=0 to L) x p(x) dx = 1/L integral (x=0 to L) x dx = L/2
<x2> = integral (x=0 to L) x2 p(x) dx = 1/L integral (x=0 to L) x2 dx = L2/3
Also, I am sorry to keep asking, but shouldn't I use normalization in this case? It seems I got wrong p(x) value?
Yes, as you can see, those expressions also have the correct dimensions and the expectation for x is L/2, which is reasonable. Yes, you should use normalisation, the normalisation is p(x) = 1/L. The problem was that you squared p(x) when computing the expectation values in your first post.
..ok, so for <x2> = integral (x=0 to L) x2 p(x) dx = 1/L integral (x=0 to L) x2 dx = L2/3 ?
(L2/3 - L/2)1/2 for root-mean square fluctation? Does this solution make any sense for the problem? I am sorry but I thought I wouldn't get any squared values in the solution.
You are now missing the square of the expectation value of x (i.e., <x>^2). You can see that your expression does not make sense since you are trying to subtract something with units length from something with units length squared. Once you have this sorted out, you can always pull out L^2 as an L outside of the square root.
