How do I implement spring supports in ANSYS?
  • Thread starter Thread starter Bref
    Ansys Springs
This discussion focuses on implementing spring supports in ANSYS, specifically using the COMBIN13 and COMBIN14 elements. Users are seeking guidance on obtaining forces in springs under various loads and the implementation of torsional springs. The conversation highlights the importance of correctly setting up element types and real constant sets in ANSYS 11.0 to achieve accurate results. Participants emphasize the need to reference the element documentation for querying spring properties such as stretch and force.
  • Familiarity with ANSYS software, particularly version 11.0
  • Understanding of spring elements COMBIN13 and COMBIN14
  • Knowledge of axial loading and torsional spring mechanics
  • Ability to navigate and interpret ANSYS element reference documentation
  • Research how to implement COMBIN13 and COMBIN14 spring elements in ANSYS
  • Learn how to query spring properties like stretch and force in ANSYS
  • Explore tutorials on torsional spring implementation in ANSYS
  • Review the ANSYS element reference for detailed specifications and examples
Mechanical engineers, simulation analysts, and anyone involved in finite element analysis using ANSYS who needs to implement and analyze spring supports in their models.
Bref
Hi Guys,
I have been trying to implement this in ANSYS all day. It is probably really simple but could you please help me:
http://yfrog.com/jlspringsupportp
The trouble is the spring supports. I basically want to get the forces in the springs due to different loads. I can't find a tutorial anywhere on spring supports.
Thanks
Isn't there a rod element that can have axial loading only? Adjust the area and modulus to get the spring constant you need.
I believe he wants the reactions of a non-statically determinable system.
It depends on what type of spring element you're using. I believe the simple 1D longitudinal springs COMBIN13 have an element solution you can query to get spring "stretch", force, and other things. Look though the element reference to see what exactly you need to query.
Hello,
I've been messing with ANSYS for days as well, but simply cannot find how to implement a torsional spring on my system (c1 and c2 in my attachment).
I tried to use the spring element COMBIN14 (this is in ANSYS 11.0; I guess this is the same as COMBIN13) and create this element at coincident nodes.
I double-checked the settings of Element types and Real constant sets, so that doesn't seem to be the problem.
Can someone help me on this?
Many thanks!
  • · Replies 24 ·
