Mentor
- 37,153
- 16,238
It absolutely is a la carte. That is the whole point of an interpretation.alexandrinushka said:No, it is not à la carte, as you suggest, @Dale . Your future is either there or it isn't...
Let's take a step back. A theory is a mathematical framework with a mapping from the math to experiment. This mapping from math to experiment is sometimes called the minimal interpretation. The framework together with the minimal interpretation is the minimum necessary for doing science. The minimal interpretation allows you to challenge the mathematical framework experimentally using the scientific method.
Now, it is possible to go beyond the original mathematical framework and make a whole new mathematical framework, perhaps even with its own minimal interpretation. If that new framework and new minimal interpretation make all of the same experimental predictions as the original, then it is called a reformulation of the original. They are not considered separate theories, and usually there is a clear mathematical way to derive one framework from the other. For example, Newton-Cartan gravity is a geometrical reformulation of Newtonian gravity wherein gravity is represented as spacetime curvature. This is not general relativity, it is Newtonian gravity, but it shares a lot of the math with general relativity. In particular, in standard Newtonian gravity gravity is a real force, but in the Newton-Cartan reformulation gravity is a fictitious force.
It is also possible to go beyond the original mapping from the math to experiment and include mappings from the math to other concepts, usually philosophical in nature. This is called an interpretation, meaning an interpretation beyond the minimal interpretation. An interpretation, by definition, cannot be queried experimentally because all of the mappings between the math and experiment are already contained in the minimal interpretation.
So, if we want to be consistent with how the world works, then what must we do? Ultimately, experiment is what we use to assess how consistent our concepts are with the world. Things that can be determined by experiment reflect some fact about the world itself and things that cannot (even in principle) be determined by experiment do not reflect some fact about the world itself.
Neither interpretations nor reformulations can be distinguished by experiment, even in principle. All reformulations of a theory and all interpretations of a theory agree on all experimental predictions. Thus neither interpretations nor reformulations reflect some fact about the world itself. They are only concepts in our mind, and as such, we can change our mind about them without coming into conflict with how the world works.
