Mass of aluminum carbonate reacting with sulfuric acid
6 replies · 3K views
jessie12
Aluminum carbonatereacts with 50.0 mL of a .250M solution of Sulfuric Acid to produce alumminum sulfate, carbon dioxode, and liquid water
the question is: What is the mass of aluminum carbonate required in grams?
HINT: Balanced Reaction. Reactants, Products
I balanced the equation, I just dnt know what to do after tht?
How many moles of sulfuric acid?
Note: you should follow template, otherwise your question can be deleted.
ooppss i thought i did...I didnt guiet understand the template thing
jessie12,
The main thing either with or without usage of the suggested template, is that you need to try to follow guidance and hints, and you need to show some effort or show some work attempt. Show us your attempt to write and balance the reaction.
