AP Physics - Freely Falling Objects
1 replies · 3K views
Blodwynne
I. A model rocket is launched straight upwards with an initial speed of 50.0 m/s. It accelerates with a constant upward acceleration of 2.00 m/s2 until it's engines stop at an altitude of 150 m.
I found a thread with an extremely similar question, but the only reply that showed up was a formula, which didn't list the meanings of the variables. I'm pretty sure I could solve this if someone could help me to fill out a data table like this:
Initial Velocity: 50.0 m/s
Final Velocity: 0.0 m/s ?
Change in Velocity:
Average Velocity:
Acceleration:
Distance: x
Time:
I only need enough variables to solve, and even then just a springboard to give me the right direction. I'm getting confused by the rocket accelerating to a certain point and then coasting past.
II. Two students are on a balcony 19.6 m above the street. One student throws aball vertically downward at 14.7 m/s; at the same instant, the pther student throws a ball vertically upward at the same speed. What is the difference of the two balls' time in the ai, and what is the velocity of each ball as it hits the ground?
Part of what is confusing me here is the vertically downward phrase, and how that effects the acceleratin (assuming -9.8 m/s2 is used here)
Data Table
Initial Velocity: -14.7 m/s (B1), 14.7 m/s (B2)
Final Velocity:
Change in Velocity:
Average velocity:
Acceleration: -9.8 m/s2
Distance: 19.6 m
Time
Again, just need to know enough variables to use an equation and/or a step in the right direction.
Thanks!
on Phys.org
Question 1:
So what exactly are you trying to find? Maximum altitude? The way to approach this is to break it up in sections. One when it's accelerating, one when it's not. You can use information from one section to find stuff that will be useful in the other section.
Question 2:
Have you drawn this out and labeled it? Based on what is given, what do you think you can work out? You will need to use more than one equation to get your final answer.
Take a look at your kinematics equations for projectile motion.
