Why is the equation for KVL not -vR + vL = 0 in this RL circuit?
  • Thread starter Thread starter caesius
    Kvl
The discussion clarifies the application of Kirchhoff's Voltage Law (KVL) in source-free RL circuits, specifically addressing the equation Ri + vL = 0, which leads to vR + vL = 0. The confusion arises from the interpretation of voltage drops across components in series versus parallel. The correct approach involves recognizing that while the components are in series (same current), they also share the same voltage drop due to being in parallel. This duality is crucial for accurate circuit analysis.
  • Understanding of Kirchhoff's Voltage Law (KVL)
  • Basic knowledge of RL circuits
  • Familiarity with voltage and current relationships in series and parallel circuits
  • Ability to interpret circuit diagrams
  • Study the derivation of KVL in RL circuits
  • Learn about the behavior of current and voltage in series and parallel configurations
  • Explore the implications of sign conventions in circuit analysis
  • Investigate the transient response of RL circuits using differential equations
Electrical engineering students, circuit designers, and anyone studying the principles of circuit analysis and KVL in RL circuits.
caesius
Not really a problem, but we're learning about source-free RL circuits and the instructor was deriving the current w.r.t time. I've actually seen this derived a few times but one thing has always bothered me.
Looking at this picture recreated from the text
http://homebrew.net.nz/RL.png
The equation dervied from it says:
Ri + vL = 0
which implies vR + vL = 0
but I've always thought that with KVL you simply write down the first sign you hit when tranversing the circuit, i.e., why is the equation not
-vR + vL = 0
Surely since the two components are in parallel the voltage drop across them has to be equal??!
Thanks if anyone can clear up my confusion
They are in series. We want to say that the currents through
L and R are equal. We use this circulating current direction as
our sign convention for vL and vR.
vL +vR = 0
Since the direction of i is defined opposite to the actual current you'd get with a positive voltage across R, we have
VR = - i R
Equate this expression with VL and see what you get.
p.s. FYI, in this case the two elements are both in parallel (same voltage) and in series (same current).
9K
