Apparent weight on an elevator. Magnitude of its acceleration?
The discussion centers on calculating the acceleration of an elevator based on the apparent weight change experienced by a person standing on a scale. The individual weighs 160 lb (75.574 kg) but the scale reads 123 lb (55.792 kg), indicating a downward acceleration of the elevator. The correct calculation involves using the equation 740.625 N = 55.792 kg * a, leading to an acceleration of approximately 7.234 m/s². The participants conclude that the elevator is accelerating downwards, which reduces the apparent weight.
  • Understanding of Newton's second law of motion (F=ma)
  • Knowledge of weight conversion from pounds to kilograms
  • Familiarity with gravitational acceleration (g = 9.8 m/s²)
  • Basic algebra for solving equations
  • Study the relationship between weight and acceleration in non-inertial frames
  • Learn about forces acting on objects in elevators
  • Explore the concept of apparent weight in varying acceleration scenarios
  • Investigate real-world applications of Newton's laws in engineering
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to explain concepts of acceleration and apparent weight in practical scenarios.
WPCareyDevil
You are standing on a bathroom scale inside an elevator. Your weight is 160 lb, but the reading of the scale is 123 lb.
(a) What is the magnitude and direction of the acceleration of the elevator?
? m/s2
(b) Can you tell whether the elevator is speeding up or slowing down?
do not know
slowing down
speeding up
weight=mg
ma=ma
160lbs = 75.574kg
123lbs: 55.792kg
g= 9.8ms
obviously, the elevator is accelerating downwards, reducing his apparent weight.
his weight when on the ground is 740.625N.
So, 740.625=55.792a
a=13.27475. The question is asking for magnitude, but there is no x component so sqrt(a^2) would still be 13.27475
Obviously, this isn't correct. Can someone point me in the right direction?
? m/s2
do not know
slowing down
speeding up
weight=mg
ma=ma
160lbs = 75.574kg
123lbs: 55.792kg
g= 9.8ms
So, 740.625=55.792a
If it was slowing down while going up it could read the same. All you know is acceleration is less down on the scales.
Ahh, you're right. That makes sense - I didnt think of that.
I tried using -13.27, and subtracting 9.8. What am I missing with the calculation?
Thank you for the tip!
WPCareyDevil said:
Ahh, you're right. That makes sense - I didnt think of that.I tried using -13.27, and subtracting 9.8. What am I missing with the calculation?
You can divide by like equations.
9.8/160 = x/123
I know the units are silly but they cancel as long as your acceleration is to be in m/s2
The difference then with 9.8 must be the acceleration in the same direction as g.
Thank you so very much!
I was able to figure it out after a bit of tweaking.
This place is the best =D. I've tried to go through answering peoples questions- but I find that I either cannot answer them well enough, or someone has already beat me to it. I'll try to give back as much as I can
You're welcome. Glad that it helped. All contributions welcome.
Cheers.
WPCareyDevil said:
So, 740.625=55.792a
a=13.27475.
Maybe I'm wrong, but I think it should be 546.762=75.574a so a=7.234.
  • · Replies 24 ·
12K
