How Does Gauss' Law Apply to an Insulated Cylindrical Shell and Rod System?
The discussion centers on applying Gauss' Law to an insulated cylindrical shell and rod system, specifically an infinitely long insulating cylindrical rod with a positive charge density of ##\lambda## and a surrounding thin conducting cylindrical shell with a charge density of ##-2\lambda##. Participants clarify that the electric field inside the cylindrical shell, for the region ##R_1 < r < R_2##, is solely due to the rod, as the contributions from the shell cancel out. This conclusion aligns with the shell theorem, which states that the electric field inside a uniformly charged shell is zero, a principle that extends to infinite cylindrical geometries.
  • Understanding of Gauss' Law and its applications
  • Familiarity with the shell theorem in electrostatics
  • Knowledge of electric field concepts and calculations
  • Basic principles of charge distribution in conductors and insulators
  • Study the mathematical derivation of Gauss' Law for cylindrical geometries
  • Explore the shell theorem and its implications for electric fields
  • Learn about the behavior of electric fields in conducting and insulating materials
  • Investigate practical applications of Gauss' Law in real-world electrostatic problems
This discussion is beneficial for physics students, educators, and professionals in electrical engineering, particularly those focusing on electrostatics and field theory.
Faiq
Question
An infinitely long insulating cylindrical rod with a positive charge ##\lambda## per unit length and of radius ##R_1## is surrounded by a thin conducting cylindrical shell (which is also infinitely long) with a charge per unit length of ##-2\lambda## and radius ##R_2##.
Find the radial component of electric field at all points in space.
https://prnt.sc/iaeer9
Confusion
I was able to calculate the electric field outside the cylindrical shell.
However a problem I am having is calculating the electric field inside the cylindrical shell.
I have some trouble reconciling the fact that the electric field inside the cylindrical shell is independent of the charge present on the cylindrical shell, as evidenced by Gauss law since constructing a Gaussian surface inside the cylindrical shell will result in enclosing of the rod.
This implies that whether the shell is present or not, the electric field inside the shell is only due to the rod.
Why is that the case?
My argument against the above reasoning is Gauss law is inapplicable in this situation since the shell is insulating and hence the charges present on it will contribute to providing an electric field. Consequently, the electric field at any ##r## such that ##R_1<r<R_2## will not only be affected by the rod but also by the electric field produced by the shell.
Faiq said:
Consequently, the electric field at any rr such that R1<r<R2 will not only be affected by the rod but also by the electric field produced by the shell.
Suppose the inner rod is removed and you have just the outer charged cylindrical shell. What do you think the electric field is inside the shell? Can you draw electric field lines? Remember they have to start at positive charges and stop at negative charges.
Yes, the charge on each small piece of the shell produces an electric field at a point inside the shell. Nevertheless, the sum of the contributions at that point from all pieces of the shell is zero. For a spherical shell, this is part of the famous shell theorem which was first proved by Isaac Newton:
https://en.wikipedia.org/wiki/Shell_theorem
I've never seen it done for an infinitely-long cylindrical shell, but I expect that a similar integral would give the same result for that case.
This a special case of Newton's shell theorem. https://en.wikipedia.org/wiki/Shell_theorem
The theorem states that for fields with ##1/r^{2}## dependence, the field is zero for any point within a uniform spherical shell. The theorem also works for an infinite cylinder since this geometry simplifies to a 2-d sphere (a circle). The link above describes both a geometric and calculus based proof of the theorem.
What did you get for the electric field inside the conducting material? The problem asks for the electric field for all values of the radius.
  • · Replies 23 ·
