Application of Quadratic Functions that involve finding equation
17 replies · 3K views · last reply
Evangeline101
Printed word problem: A jet flew from Tokyo to Bangkok, a distance of 4800 km. On the return trip, the speed was decreased by 200 km/h. If the difference in the times of the flights was 2 hours, what was the jet's speed from Bangkok to Tokyo? (13 marks)
none
Table of distance, speed and time for a Tokyo to Bangkok and Bangkok to Tokyo flight, followed by the equation 4800/x - 4800/(x+200) = 2 and its algebraic solution giving x = 600.
Is this correct?
Thanks.
Evangeline101 said:
[ ATTACH=full]101053[/ATTACH]
none
[ ATTACH=full]101054[/ATTACH]
Is this correct?
Thanks.
The answer is correct.
There are errors in your work starting with the table.
If x is the speed from Tokyo to Bangkok then reducing that by 200 gives a speed of x - 200 from Bangkok to Tokyo. Etc.
I understand where I made the error, the return trip speed decreased by 200 km/h, so it should have been (x-200) not (x+200), so I have corrected my answer:
Handwritten-style algebra solving 4800/x - 4800/(x-200) = 2 by clearing denominators, reaching x^2 + 200x - 480 000 = 0, factoring to (x+800)(x-600), and concluding x = 600 km/h.
Thanks for the help! :)
Evangeline101 said:
I understand where I made the error, the return trip speed decreased by 200 km/h, so it should have been (x-200) not (x+200), so I have corrected my answer:[ ATTACH=full]101104[/ATTACH]
There's still a problem, x is the Tokyo to Bangkok speed. That can't be 600mph. 600 - 200 is 400, and that doesn't work out.
So, where is the problem?
You made a couple of errors.
Sign errors in going from
##-960000=2x^2-400x ##​
to
##2x^2+400x-960000= 0 ##​
It should be
##2x^2-400x+960000= 0 ##​
But there is no real solution to that.
The problem is that it's the Tokyo to Bangkok time that's smaller, because the speed is greater. When you subtract to get 2 hours, you need to subtract in the opposite order.
−960000=2x2−400x−960000=2x2−400x-960000=2x^2-400x to
2x2+400x−960000=02x2+400x−960000=02x^2+400x-960000= 0 It should be
2x2−400x+960000=02x2−400x+960000=02x^2-400x+960000= 0 But there is no real solution to that.
I tried doing it this way, but as you said there is no real solution.
I don't understand what you mean, can you please explain?
If x > 200, then
##\displaystyle \frac{4800}{x-200}>\frac{4800}{x}##​
So you had these reversed.
SammyS said:
If x > 200, then
4800x−200>4800x4800x−200>4800x\displaystyle \frac{4800}{x-200}>\frac{4800}{x}.
So even if I switch these two, can I not get the same answer I had originally? How does switching the two help with the answer to the problem? or is it just the proper way to write it?
It's what is needed of you want to make everything consistent.
As I stated in my first reply, the answer you gave for the time from Bangkok to Tokyo was correct. (600 km/hr)
But you had a number of inconsistencies.
Added in Edit:
You should get x = 800. Then x- 200 = 600, the answer.
Added in Edit:
So like this:
Handwritten-style algebra solving 4800/(x-200) - 4800/x = 2 by clearing denominators, reducing to x^2 + 200x - 480 000 = 0, factoring as (x+800)(x-600), giving x = -800 or x = 600.
Evangeline101 said:
So like this:
No.Not like that.
The first three lines are correct.
After that, there are at least two Algebra mistakes.
As I stated in my previous post:
This is an example from my lesson that I have been using as a reference to solve my problem:
Textbook worked example table setting up a round-trip distance-speed-time equation: 4200 km trips at speeds x and x + 100 km/h, times 4200/x and 4200/(x + 100), total 13 hours.
Worked solution on a textbook page solving 4200/x + 4200/(x+100) = 13 by multiplying through by x(x+100), expanding, factoring 13x^2 - 7100x - 420000 = 0 as (13x+700)(x-600), and rejecting the negative root, giving 600 km/h.
Right. And they did not make algebra mistakes. You did.
So (carefully) redo your algebra, starting at the third line of the following (from post #10), which is the last line that's correct.
Handwritten-style algebra working solving 4800/(x-200) - 4800/x = 2 by multiplying through by x(x-200), ending with the roots x = -800 or x = 600.
SammyS said:
No.Not like that.
Handwritten algebra steps: 4800/(x-200) - 4800/x = 2, then multiplying both sides by x(x-200), then 4800x - 4800(x-200) = 2x(x-200).
4800x - 4800x + 960 000 = 2x2 - 400x (960 000 is positive because I multiplied -4800 and -200)
960 000 = 2x2 - 400x (Now I move 960 000 to the right side and it becomes -960 000)
2x2 - 400x - 960 000 = 0
x2 - 200x - 480 000 = 0
(x+600) (x-800)
x= -600 or x = 800
Does this make more sense? did I fix the algebra errors? if not please show me where I made errors.
  • Handwritten-style algebra: 4800/(x-200) - 4800/x = 2, then both sides multiplied by x(x-200), giving 4800x - 4800(x-200) = 2x(x-200).
Evangeline101 said:
View attachment 1011774800x - 4800x + 960 000 = 2x2 - 400x (960 000 is positive because I multiplied -4800 and -200)
(x+600) (x-800) = 0
x= -600 or x = 800
Yes. That looks to be correct.
Okay, so does that make the speed from Bangkok to Tokyo 800 km/h instead of 600 km/h since it is positive?
So since x = 800, we need to solve for the jets's speed from Bangkok to Tokyo, so (like you said) sub x = 800 into x- 200, which gives:
800 - 200 = 600 km/h
So the jet's speed from Bangkok to Tokyo is 600 km/h.
