Applying Faraday's law when the loop itself is changing size
59 replies · 16K views · last reply
pardesi
well iwas going through the standard example that is there is a uniform magnetic field in aregion going into the palne and ther is a rectangular 'loop' with one side which can slide on metallic rods with constant speed [tex]v[/tex] and the the relation
[tex]\epsilon=BLv[/tex]
well the example is (almost) here
well i could intutively understand that from lorentz' force concept that when the side starts moving so do the electrons so they experience a force and a current is produced.
well i wanted to go about it from farady's alw.well what i couldn't get is farady's law states when the "flux across a circuit...".but here our loop itself is changing so how do i utilize the law
pardesi said:
but here the 'loop' itself is not constant
What do you mean by the loop is not constant ?
Generally, the flux changes due to :
1) change in the position of the loop with respect to the B-field (rotation or translation)
2) the loop changes its form (rectangle becomes circle eg).
The basic ingredient is the fact that the flux must change with respect to time ! If this does not happen, no potential is created.
marlon
i mean here the rectangle grows in size it does have a change in area but this change is due to addition of 'more conducting element' as oppsoed to whenit changes toa circle in which the lopp is 'constant' but it's shape changes
First of all, if it changes in surface, this means that the flux WILL change and a voltage will be created.
But how does the rectangle increases its surface ? I don't get the "due to more conducting elements" reasoning.
marlon
well what i meant was consider the rectangular loop PQRS no suppose i start stretching it or change it into a circle in presence of a mganetic field then the flux changes and an 'emf' is induced across the loop PQRS.
but here the loop PQRS not only schanges its' shape but also gets some additional new elements.
How does the loop acquire additional new elemnts and what are these elements ? I really don't get it. Besides, what exactly do you want to know other than the consequence of the applicaton of Faraday's law which we covered here.
marlon
well i got thsi ...i read that in griffith where it is explained nicely...well it is sheer coincidence he writes that the motional emf has the same formula as that for the other two cases...
great:smile:
great:smile:
By motional emf you mean the moving loop right ? What same formula ? You mean Faraday's Law ?
Actually, could you explain the solution to your problem to me because i don't get it.
marlon
yes motional emf means moving coil but stationary fie;d(here).
and the formula refers to faraday's law
if u could get a copy of griffith then he very beutifully denies to accept that the emf induced due to motion of the cil as the one given by faraday's law.infact goes on to say that in some sense it is not the 'true' farady's law that holds here.
and most probably for the reason which i was worrying about
because if u go through faraday's law it starts witha line that "if through a loop..." so the loop is fixed and by loop i mean a collection some points.
but while we consider the motional emf as in my case the rectangle is taken to be the loop whose one side is moving.so the 'points' which make up the loop are not the same.
crudely speaking the loop itself is changing
so there is no point in assuming 'farday's law' for granted...though he discovered for this case also.it is just sheer coincidence taht thsi happened
That's incorrect. What matters is the variation of the flux with respect to time, inside the loop. The loop may vary in structure as well.
marlon
If you're hopelessly confused by the area changing (honestly, I don't see why), just perform a line integral of the electric field around some closed curve.
http://www.ucl.ac.uk/Mathematics/geomath/level2/mult/mi3.html
You will find that the intergal over a curve of the electric field component pointing along the curve is non-zero.
If you like, you can use a vector identity to convert this line integral into an area integral. This is known as stokes theorem. This is why people are talking about integrating the flux, this is justified by Stokes theorem.
i am not worried about the changing area...and stokes theorem is fine
also when u ask me to calculate the line integral it has to be about a fixed loop
what i am worried about is when we say that flux through a loop changes ...then obviously the flux has to be through a fixed loop,obviously i f i vary my loop with time my flux has to change(in most cases) ,so what i am saying is though the faraday's law holds true in case of motional emf...but that's just because it coincidentally happened to be so...
what i am opposing is 'direct' use of farady's law in getting the induced emf in case of motional emf..though it gives u the right answer but that won't be using faraday's laws in the right sense,as most books do (thankfully griffith didn't) and for the reason i stated above
to clarify things further as in this case the we assume the loop to be the rectangle PQRS then calculate the flux through it at any time t to be [tex]\Phi=Blx[/tex]
then we write [tex]E=\frac{d \Phi}{dt}=Blv[/tex] where [tex]v[/tex] is the speed of the movable side.
but this makes no sense because the flux through the loop is not changing as the field is constant here.what actually is changing is the loop which we are considering so the calculated flux changes.though the flux through PQRS is not changing.
also here the emf induced is best explained by lorentz force.
it is just by sheere coincidence(and i repeat) that what we do is working out right.
But can't you see the contradictio in terminis in the above two sentences ? First you say the flux is constant, then you say it changes. Again, the flux IS changing because the number of magnetic fieldlines in the loop changes with time. The reason of this change is the varying loop ! The flux can change due to 1) the B field or 2) the loop that encloses the field lines !
marlon
yes what i am saying is the flux through any loop is not changing with time.what is changing is the loop which we have taken into consideration.
say for example there is magnetic field uniform in a room.at time t i take my loop to be a square one inside the room.the next moment 'i' will take my loop to be a square one outside the room.so where will the induced emf be .
again i say the thing is the proof by faraday' law is not all correct(at least to me).lorentz force proof seems right.
Again, if the loop is changing the flux is also changing. I would advise you to carefully investigate the definition of FLUX. After having done that, you will understand that what you are saying is incorrect.
Yes because the flux has changed. Again, make sure you look at the definition of flux.
marlon
flux [tex]\phi = \int_{S} \vec B . \vec dS[/tex]
by loop i mean any fixed loop .consider any loop u want to the flux through it doesn't change with time.what is changing is the loop u are considering .so just because u r changing the loop of your consideration why should an emf be developed.
when u say the flux has changed can u tell me flux through what has changed?
Faraday's Law, in integral form, states that at any given time, if a fixed closed loop is taken, the line integral of E around that closed loop is equal to the negative of the derivative of the magnetic flux through any surface bounded by the loop. The loop, as referred to in Faraday's law, MUST be fixed. I agree with you completely, in that respect.
In my view, this is how to resolve your question:
In order to find the emf at any time t, consider the fixed loop with dimensions l and vt. From time 0 to time t, the negative of the rate of change of magnetic flux through this fixed loop is -Blv. Even before the moving conducting rod reaches the position of one side of the fixed loop, this is still the rate of change of magnetic flux through the loop. When the conducting rod finally reaches position vt, the voltage of the physical circuit becomes -Blv. Although the physical circuit has changed, we are only concerning ourselves with a fixed loop when we calculate the emf at an arbitrary time t.
u can also go through the proof using the lorentz force.it seems really good and fundamental.
But if the loop changes, the above integral will have a different outcome as well and thus, your calculated flux has changed !
marlon
yes that's what i am telling our loop itself is changing and farady's law talks of a fixed loop.
anyway when u change the loop then on which loop will the emf be developed or mathematically which loop's line integration...will be the rate of cahnge of flux.
take the very sam example i gava couple of posts back.
just because u have taken a loop once inside the room and the next moment outside another completely different from nowhere why should there be an induced electric field?
Yes, that's a very good illustration of the fact that Faraday's Law refers integration around a fixed path.
You still need to carefully consider the concept of flux. The magnetic flux through the loop is a function of the magnetic field distribution, the area of the loop and the angle at which the vector defining the plane of the loop (the vector normal to the loop), dS, makes with the B-field at any given point in the loop. The key issue here is the DOT PRODUCT in the definition of the flux.
oops...for some reason I thought this was a problem dealing with a rotating loop...well, Faraday's law STILL applies to your situation. But instead of the angle the loop makes with the B-field changing, the AREA of the loop is changing.
No, this is incorrect. Faraday's law handles motional EMF (moving loop) just fine.
I repeat, the integral form of Faraday's law holds for BOTH motional EMF (EMF induced in a moving conductor in a B-field) and transformer EMF (EMF induced in a stationary conductor in a time invariant B-field).
However, the differential form of Faraday's law (curl of E = -dB/dt) only holds for transformer EMF (fixed loop).
I read in Jackson that faraday’s law works for any area whether it is changing because of change of size, rotation, stationary, etc.
It seems to me you are nervous about the sliding contacts of the moving conductor. As it slides, more of the stationary part of the mechanism is added to the circuit. Instead of sliding contacts, imagine that the wire is folded up at the intersection between the moving and stationary part of the circuit. As the moving section moves, the wire unfolds. Now all parts of the circuit are always in the same magnetic field, and the generated voltage will be Blv.
That's what I thought, but haven't had a chance to dig into my books (Jackson et al.) to verify. Thanks for saving me that work. :)
What we call the integral form of Faraday's law,
[tex]\varepsilon = - \frac {d \Phi_B} {d t}[/tex]
includes two kinds of emf [itex]\varepsilon[/itex]: (a) the emf produced by the electric force on the electrons:
[tex]\varepsilon_E = \frac{1}{q} \oint {\vec F_{elec} \cdot d \vec \ell} = \oint {\vec E \cdot d \vec \ell}[/tex]
and (b) the motional emf produced by the magnetic force on the electrons that is caused by the motion of the wire:
[tex]\varepsilon_B = \frac{1}{q} \oint {\vec F_{mag} \cdot d \vec \ell} = \oint {(\vec v \times \vec B) \cdot d \vec \ell}[/itex]<br /> <br /> If the loop of wire is fixed ([itex]\vec v = 0[/itex] all around the loop) , then [itex]\varepsilon_B = 0[/itex] and [itex]\varepsilon= \varepsilon_E[/itex]. If the loop is changing size or shape, then [itex]\varepsilon= \varepsilon_E + \varepsilon_B[/itex].<br /> <br /> When you take the differential form of Faraday's law (without currents)<br /> <br /> [tex]\nabla \times E = - \frac {\partial \vec B} {\partial t}[/tex]<br /> <br /> and apply Stokes's Theorem to convert it to an integral equation (which requires a fixed loop for the line integral on the right-hand side), the left-hand side gives you only [itex]\varepsilon_E[/itex]. This is not the complete "integral version of Faraday's law" because it doesn't include [itex]\varepsilon_B[/itex]. Including [itex]\varepsilon_B[/itex] allows us to relax the requirement that we use a fixed loop when calculating [itex]\Phi_B[/itex].<br /> <br /> So what we call the "integral version of Faraday's law" is not purely the integral of the differential version of Faraday's Law.[/tex]
i never said farday's law was wrong..what is said is that faraday's law although it holds for motional case as u can see above can only be in some sense 'extended' by including the lorentz force term.
now the question is why?:
because when the loop itself is changing talking of an 'induced emf' is somewhat confusing and meaningless because our loop itself is not fixed.further for a time-independent magnetic field flux through any loop is time independentand a proof as given in some books without acknowledging lorentz force is not that correct.
again why?
go to my previous example where u physically had no loop.but just a collection of points(u thought of it) inside a room with uniform magnetic field .then u thought of another loop outside the room where there is no magnetic field...and then u say flux is changing hence u have an induced field well that's meaningless ?
