Applying Itos Lemma to show one SDE is related to another.
  • Thread starter Thread starter jend23
The discussion focuses on applying Ito's Lemma to derive the stochastic differential equation (SDE) for the process defined by d√z = (α - β√z)dt + δdW, where α, β, and δ are constants. The correct application of Ito's Lemma reveals that dz = (δ² + 2α√z - 2βz)dt + 2δ√zdW. Key steps include recognizing the transformation y = √z and correctly identifying the drift and diffusion components in the context of the lemma.
  • Understanding of Ito's Lemma and its application in stochastic calculus.
  • Familiarity with stochastic differential equations (SDEs) and their components.
  • Knowledge of partial derivatives and their role in mathematical modeling.
  • Basic understanding of Wiener processes and their properties.
  • Study the derivation and applications of Ito's Lemma in various stochastic processes.
  • Explore advanced topics in stochastic calculus, such as Girsanov's theorem.
  • Learn about the implications of different types of SDEs in financial modeling.
  • Investigate numerical methods for solving SDEs, including the Euler-Maruyama method.
Mathematicians, quantitative analysts, and students of stochastic calculus seeking to deepen their understanding of Ito's Lemma and its applications in modeling stochastic processes.
jend23
Hello,
Given the process
[tex] d\sqrt{z} = (\alpha - \beta\sqrt{z})dt + \delta dW[/tex]
[itex]\alpha[/itex], [itex]\beta[/itex] and [itex]\delta[/itex] are constants.
Use Ito's Lemma to show that:
[tex] dz = (\delta^2 + 2\alpha\sqrt{z} - 2\beta z)dt + 2\delta\sqrt{z}dW[/tex]
Itos Lemma:
[tex] df = \left(\frac{∂f}{∂t} + \frac{1}{2}\frac{∂^2f}{∂W^2}\right)dt + \frac{∂f}{∂W}dW[/tex]
where [itex]t[/itex] is time and [itex]W[/itex] a Wiener process.
Essentially, I have a bit of a mental block about how to start going about solving this. I'm sure it's relatively simple though if I had a hint on the right direction to take.
In the first equation, the diffusion coefficient is:
[tex] \frac{∂f}{∂W} = \delta[/tex]
The drift is:
[tex] \frac{∂f}{∂t} + \frac{1}{2}\frac{∂^2f}{∂W^2} = \alpha - \beta\sqrt{z}[/tex]
I also know that [itex]dW^2[/itex] can be replaced with [itex]dt[/itex].
To simplify, let [itex]y=\sqrt{z}[/itex] so the SDE becomes:
[tex] dy = (\alpha - \beta y)dt + \delta dW[/tex]
Can we use the simpler form of Ito's Lemma since drift does not seem to be a function of t i.e. [itex]\frac{∂f}{∂t}[/itex] is 0 and the partial derivatives can become ordinary derivatives?
I don't really know where to go from there. I'm sure I'm missing something simple and obvious. Ideally, if possible I'd like to be given a hint about how to go about solving this problem.
Any help appreciated. Thanks.
jend23 said:
Hello,
Given the process
Itos Lemma:
The drift is:
You are mis-stating Ito's Lemma. You should have: if [tex]dX = a(X,t) dt + b(X,t) dW[/tex] and if ##Y = f(X,t)##, then
[tex]dY = f_{x}(X,t)\, dX + f_t(X,t)\, dt + \frac{1}{2} f_{xx}(X,t) b^2(X,t) dt[/tex]
In your case,
[tex]X = \sqrt{z}, \: Y = X^2.[/tex]
In your case,
Thanks for the pointer and after reviewing my notes a few more times, it has now become embarrassingly obvious. Much appreciated.
So, we have
[tex] dX = (\alpha - \beta X)dt + \delta dW[/tex]
[tex] \frac{∂Y}{∂t} = 0, \frac{∂Y}{∂X} = 2x, \frac{∂^2Y}{∂X^2} = 2[/tex]
therefore, from (slightly different notation and arrangement to your one):
[tex] dY = \left(\frac{∂Y}{∂t} + a(X,t)\frac{∂Y}{∂X} + \frac{1}{2}b(X,t)^2\frac{∂^2Y}{∂X^2}\right)dt + b(X,t)\frac{∂Y}{∂X}dW[/tex]
we have:
[tex] dY = \left( 0 + (\alpha - \beta X)(2X) + \frac{1}{2}\delta^2(2) \right)dt + \delta(2X)dW[/tex]
[tex] = \left(2\alpha X - 2\beta X^2 + \delta^2 \right)dt + 2\delta X dW[/tex]
substituting back ##\sqrt{z}## for ##X## yields the required result.
Thanks again!
