Applying the fourier transform to a PDE
This discussion focuses on applying the Fourier transform to solve the heat equation, specifically the partial differential equation (PDE) given by {\frac{∂u}{∂t}} = {\frac{∂^2u}{∂x^2}} with the initial condition u(x,0) = 70e^{-{\frac{1}{2}}{x^2}}. The solution derived is u(x,t) = {\frac{70}{\sqrt{1+2t}}}{e^{-{\frac{x^2}{2+4t}}}}. The Fourier transform is defined as U(k) = F{u(x)} = {\frac{1}{\sqrt{2π}}}{\int_{-∞}^{∞}{{u(x)}{e^{-ikx}}}\,dx}, and the user seeks a more straightforward method for performing the inverse Fourier transform to obtain u(x,t).
  • Understanding of the heat equation and its mathematical formulation.
  • Familiarity with Fourier transforms and their properties.
  • Knowledge of Gaussian functions and their integrals.
  • Experience with inverse Fourier transform techniques.
  • Study the properties of the Fourier transform of Gaussian functions.
  • Learn techniques for completing the square in exponential integrals.
  • Explore Fourier transform tables for common functions.
  • Practice inverse Fourier transform calculations with various initial conditions.
Mathematics students, physicists, and engineers working with partial differential equations, particularly those interested in heat transfer and wave propagation analysis.
_Stew_
I have a tutorial question for maths involving the heat equation and Fourier transform.
you are given the initial condition:
the answer is:
In this course the definition of a Fourier transform is:
U(k) = F{u(x)}= {\frac{1}{\sqrt{2π}}}{\int_{-∞}^{∞}{{u(x)}{e^{-ikx}}}\,dx}
u(x) = F^{-1}{U(k)}= {\frac{1}{\sqrt{2π}}}{\int_{-∞}^{∞}{{U(k)}{e^{+ikx}}}\,dk}
MY SOLUTION:
So far I can use the transform with the pde to obtain
U(k,t) = A(k).e^{-k^{2}t}
U(k,0) = A(k)
From the initial condition and a transform table:
U(k,0) = 70.e^{-{\frac{1}{2}}k^2}
U(k,t) = 70.e^{-{\frac{1}{2}}k^2}.e^{-k^{2}t}
from here it looks like I would have to apply the inverse Fourier transform to get u(x,t). This is a difficult integration an I don't remember it being this complicated the first time. So basically:
Is there an easier way to do this question?
Any tips for the inverse Fourier integration below?
u(x,t) = {\frac{1}{\sqrt{2π}}}{\int_{-∞}^{∞}{{70.e^{-{\frac{1}{2}}k^2}.e^{-k^{2}t}}{e^{+ikx}}}\,dk}
You have a Fourier transform of a Gaussian
$$\frac{1}{\sqrt{2\pi}} \int_{-\infty}^\infty e^{-\alpha k^2} e^{ikx}\,dk$$ where ##\alpha = t+\frac{1}{2}##, so you could just look up the answer in a table of Fourier transform pairs. If you want to derive the result, combine the exponentials and then complete the square.
