Applying two Fourier transforms to derive retarded time expression
11 replies · 3K views
user1139
Help with evaluating Fourier transform
The definition of Fourier transform (F.T.) that I am using is given as:
$$f(\vec{x},t)=\frac{1}{\sqrt{2\pi}}\int e^{-i\omega t}\tilde{f}(\vec{x},\omega)\,\mathrm{d}\omega$$
I want to show that:
$$\frac{1}{c\sqrt{2\pi}}\int e^{-i\omega t}\omega^2 e^{ikx}(\vec{x}\times\vec{p}_{\omega})\,\mathrm{d}\omega=-\frac{\vec{x}}{c}\times\frac{d^2}{dt^2}\,\vec{p}(t-x/c)$$
To show the above, two F.T. must occur to get the second derivative w.r.t. time and the ##(t-x/c)## term. However, I am not sure how to proceed since obtaining either one will induce another F.T. into the second equation. How should I continue?
Thomas1 said:
To show the above, two F.T. must occur to get the second derivative w.r.t. time and the $(t-x/c)$ term. However, I am not sure how to proceed since obtaining either one will induce another F.T. into the second equation. How should I continue?
I'm not sure what you mean here. And what is ##\vec{p}_\omega##?
##\vec{p}_{\omega}## is some function of ##\omega## which was not specified in the question. From my understanding, if I want to find let's say the derivative portion, I need to F.T. or inverse F.T.. Since there is currently only one F.T. I will need to manually insert in another F.T.. As such, there will now be two F.T..
So is ##\vec p## in the result supposed to be the Fourier transform of ##\vec p_\omega##?
Can you write out what you mean using math? It's not clear what you mean by "find the derivative portion."
No, it's just a function of ##\omega##.
What I meant was
$$\int e^{-i\omega t}\frac{d^2}{dt^2}(\vec{x}\times\vec{p}_{\omega})\,\mathrm{d}\omega=-\omega^2(\vec{x}\times\vec{p}_{\omega})$$
That can't be right. You're integrating over ##\omega##, so the righthand side can't depend on ##\omega##.
What I meant was
Same problem with that expression. On the lefthand side, you're integrating with respect to ##\omega##, which is a dummy variable, so it can't appear in the result on the righthand side.
But I think I finally understand what your question is. Say you have some function ##f(t)## and its Fourier transform ##F(\omega)##. Then you have
$$f'(t) = \frac{d}{dt} f(t) = \frac{d}{dt} \int F(\omega)e^{-i\omega t}\,d\omega = \int F(\omega)\frac{d}{dt}e^{-i\omega t}\,d\omega = \int [-i\omega\, F(\omega)] e^{-i\omega t}\,d\omega.$$ The last integral can be thought of as the Fourier transform of the function ##G(\omega) = -i\omega F(\omega)##, and it pairs with ##g(t) = f'(t)##. The integral doesn't go away when you translate ##d/dt## in the time domain into the factor ##-i\omega## in the frequency domain.
Indeed, that was what I tried to reason out. I still can't see a way to motivate ##e^{ikx}## into the F.T. and thereafter, assuming we managed to do so, I suppose we can do a combined F.T. into what was wanted?
##k## and ##\omega## are related, right?
Yes, they are. They are related by ##\omega=kc##.
Actually, is it correct to do the F.T. separately i.e. one for the derivative and the other for ##e^{ikx}## then use both results to do the combined F.T.?
It's not so much you're applying the properties separately, but you're applying them consecutively. So, for example, say you have the pair ##f## and ##F##, then ##g(t) = f''(t) \leftrightarrow G(\omega) = \omega^2 F(\omega)##. Then you can apply the next property to the pair ##g## and ##G##.
I always thought that to perform a F.T. you need to have the integral. Since there is only one integral, why is it that we can think of the F.T. to be done as consecutively rather than as combined?
On the right side of the expression in the OP , express ## p(t-x/c) ## as a F.T. integral in ## \tilde{p}(\omega) ##. You can then differentiate w.r.t. time (twice) and bring it inside the integral.
