Approximate diagonalisation of (3,3) hermitian matrix
The discussion centers on the diagonalization of a complex 3x3 Hermitian matrix K using a unitary matrix S, specifically seeking approximate expressions for S's entries in terms of K's entries. The user, Susy, inquires about methods to derive S from K, particularly when K's entries are expressed as a power series in a small parameter ε. Participants confirm that simultaneous diagonalization of K0 and Kε is feasible, with K0 typically being diagonal and Kε serving as a correction.
  • Understanding of Hermitian matrices and their properties
  • Familiarity with unitary matrices and their role in diagonalization
  • Knowledge of power series expansions and perturbation theory
  • Experience with Mathematica for symbolic computation
  • Research methods for approximate diagonalization of Hermitian matrices
  • Learn about perturbation theory in quantum mechanics
  • Explore symbolic computation techniques in Mathematica
  • Investigate generalized eigenvalue problems and their numerical solutions
Mathematicians, physicists, and computational scientists involved in matrix analysis, particularly those working with Hermitian matrices and seeking efficient diagonalization techniques.
SUSY
Hi,
I have a 3 by 3 hermitian matrix K that I need to diagonalise. More accurately, I am searching for a unitary matrix S such that S^{\dagger} K S is diagonal.
The problem is that K is very complicated and the expression for S in mathematica takes up quiiiiiet a lot of space.
Is it possible to find approximate expressions for the entries of S in terms of entries in K? What I am looking for is something like (as an example) S_{ij}=K_{ij} + K_{ji} bla bla
Or is it maybe possible to decompose S into matrices which I can then approximate by such expressions (they can, of course, be more complicated than the example given above).
Since the entries in K are given as a power series of some small parameter ε K_{ij}=a_0 + a_1 \epsilon + ... and I am only interested in the lowest non-vanishing order anyway, it would be nice to have expressions for the entries in S in terms of the entries in K. Then, I could easily evaluate the entries in S to lowest non-vanishing order in ε (so I am only interested in an approximate S anyway).
Does anybody know of such a method?
Thanks,
Susy
If you can write ##K = K_0 + \epsilon K_\epsilon##, can you diagonalize ##K_0## and ##K_\epsilon## simultaneously? This is routinely done numerically, as a generalized eigenproblem, but I don't know about doing it symbolically.
Yes, you should be able to diagonalize both simultaneously. In all cases I can think of, $K_0$ will already be a diagonal matrix and $K_{\epsilon}$ is a correction ($K_{\epsilon}$ can in principle be an arbitrary hermitian matrix).
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 0 ·
