Approximating distributions with other distributions
  • Thread starter Thread starter Gauss M.D.
    Distributions
Gauss M.D.
In shipment A, there are 990 correct and 10 faulty units. In shipment B, there are 1940 correct and 60 faulty units.
100 units out of each shipment is inspected. Calculate with an APPROPRIATE approximation the probability of finding five or more faulty units.
Emphasis from book, not me.
My solution was
A = Bin(100,0.01) ≈ N(1,0.1)
B = Bin(100,0.03) ≈ N(3,1.71)
A+B ≈ N(4,1.71)
P(A+B > 4.5) = 1-P(A+B < 4.5) = /normal table/ = 0.386
Which produced a fairly good answer, but the book also made it clear that they were looking for a poisson approximation. I am not entirely clear on why that is. Anyone?
My solution was
A+B ≈ N(4,1.71)
Perhaps what they wanted, is for you to use a Poisson approximation with mean (1+3), in which case you get:
A = Bin(100,0.01) ≈ Poisson(1)
B = Bin(100,0.03) ≈ Poisson(3)
A+B ≈ Poisson(1+3)
P(A+B >_ 5) = 1 - P(A+B <_ 4) = 1 - POISSON.DISTR(4, 1+3, cumulative) = 0.389.
Either way, they may have wanted you to associate the probability on "faulty" units with Poisson, which would be appropriate.
Btw, I get slightly different results.
My result for your normal approximation based on the binomial distribution is 0.419.
The same normal approximation based on the Poisson distribution is 0.420.
That is almost certainly what they wanted. But there doesn't seem to be any great motive for why a Poisson approximation would be BETTER than a normal approximation, right?
Btw my book says Bin(n,p) ~ N[np,sqrt(np(1-p)]. Wikipedia says Bin(n,p) ~ N[np,np(1-p)]. Is this a notation difference? My book uses N(a,b) where a is expected value, b is standard deviation.
Actually, the normal distribution is not a very good approximation where the tails of the distribution are concerned.
The Poisson distribution has a more natural resemblance to the binomial distribution, on top of being appropriate for fault behavior.
At any rate, I wouldn't call your normal approximation wrong. It's still a good approximation in this case.
Yes, these are indeed notational differences.
The parameters of the normal distribution are expected value (##\mu##) and standard deviation (##\sigma##).
Whenever you specify the normal distribution, you need to make sure to eliminate any ambiguity where the standard deviation is concerned.
As you can see in the wiki article, they've made sure to specify ##\mathcal N(\mu, \sigma^2)## first, before specifying anything with it.
Likely your book will have specified N[μ,σ] first, before making any statements using it.
My solution was
A+B ≈ N(4,1.71)
The normal approx. is not advised for a large-n, small-p case like yours. The Poisson is much better.
Note: you should have A ~ N(1,0.995), giving A+B~N(4,1.975) and P(>=4.5)=0.40006387.
The results are for P(>=5) are:
exact binomial = 0.37115~0.37
Poisson = 0.37116~0.37
Normal = 0.40006~0.40
Note: these are the Poisson approx. to the binomial, and the normal approx. to the same binomial.
My home internet connection is down, so I am using my I-phone with all its difficulties and limitations. (Computations done off-line.)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
