Arbitrary Subset of A^n - Is it necessarily an affine algebraic set?
  • Context: MHB
  • Thread starter Thread starter Math Amateur
    Set
The discussion revolves around the question of whether any arbitrary subset of the affine space $$\mathbb{A}^n$$ qualifies as an affine algebraic set. Participants explore definitions and implications from algebraic geometry, particularly focusing on the properties of affine varieties and their relationship to subsets of affine space.
  • One participant questions if any arbitrary subset of $$\mathbb{A}^n$$ can be considered an affine algebraic set, suggesting that a set with no non-zero functions vanishing at its points might qualify.
  • Another participant asserts that not every subset of $$\mathbb{A}^n$$ is an affine variety, emphasizing that the definition of an affine variety involves the common zero locus of polynomials, which may not correspond to arbitrary subsets.
  • It is noted that the zero function vanishes everywhere, and thus cannot be used to prove that a subset is an affine variety unless a specific set of functions vanishing only on that subset can be identified.
  • Examples are provided, such as the subset $$\mathbb{A}^n - \{(0, 0, \cdots, 0)\}$$, which is stated to not be an affine variety.
  • Participants discuss the concept of quasi-affine varieties as a related notion for subsets that are locally closed but not necessarily affine varieties.
Participants generally disagree on the initial claim that any subset of $$\mathbb{A}^n$$ can be an affine algebraic set. There is a clear contention regarding the definitions and properties of affine varieties, with some participants providing counterexamples to the original assertion.
The discussion highlights the complexity of defining affine algebraic sets and the necessity of specific conditions for subsets to qualify as such. The proofs and examples mentioned are noted to require advanced understanding beyond basic commutative algebra.
Math Amateur
MHB
I am trying to gain an understanding of the basics of elementary algebraic geometry and am reading Dummit and Foote Chapter 15: Commutative Rings and Algebraic Geometry ...
At present I am focused on Section 15.1 Noetherian Rings and Affine Algebraic Sets ... ...
I need someone to help me to fully understand the definition of an affine algebraic set ... ...
D&F explain and define an affine algebraic set in the following text ... ...View attachment 4750
View attachment 4751My question regarding the above definition is this:
Does any arbitrary subset (that is any subset) of the affine plane $$\mathbb{A}^n$$ qualify as an affine algebraic set ...
I was thinking maybe that it does because ... ...
If we have a set $$A_1$$, say that has no non-zero functions with zeros at each of its points, then could we regard the function corresponding to the zero polynomial as having zeros at each of the points of $$A_1$$ ... ... so that the set of functions {$$z$$} where $$z$$ is the zero function is zero on all points of $$A_1$$ ... and hence $$A_1$$ qualifies as an affine algebraic set ... ... I suspect that something is wrong with my analysis above ... but what exactly ...
Can someone clarify this issue for me please ... ...
Peter
No, it's completely false that any subset of $\Bbb A^n$ appears as an affine algebraic set (also called affine variety).
First, let's review the definition : For some subset $S \in k[x_1,\cdots, x_n]$, the affine variety corresponding to it is the common zero locus of all polynomials in $S$. That is, $V = \{(a_1, \cdots, a_n) \in \Bbb A^n : f(a_1, \cdots, a_n) = 0\}$. If $S$ is a singleton, we get zero locus of a single polynomial in $\Bbb A^n$. This is called a hypersurface.
Thus, you can visualize an affine variety as intersection of (not necessarily finitely many) hypersurfaces in $\Bbb A^n$. As a side-note, it's a fact that any affine variety can be realized as intersection of finitely many hypersurfaces - this is Hilbert's basis theorem.
OK, so now that we are done reviewing the definitions, let's get back to your question. Why should it be true that any subset of $\Bbb A^n$ is an affine variety? Let $U \subset \Bbb A^n$ be an arbitrary subset of $\Bbb A^n$. You can of course consider the set of all functions vanishing on $U$. Call the set $S \in k[x_1, \cdots, x_n]$. However, what you don't know is whether functions in $S$ vanishes on places other than $U$. By definition, however, functions in $S$ on the affine variety $\mathcal{Z}(S)$ doesn't vanish anywhere else. So $U$ might not necessarily be an affine variety.
So, there's no reason for what you say to be true. To get an explicit example, the subset $\Bbb A^n - \{(0, 0, \cdots, 0)\}$ of $\Bbb A^n$ is not an affine variety. The proofs are quite involved, and require much more than basic commutative algebra. As a side-note, it is sometimes desired that locally closed subsets of affine varieties be varieties. Thus, we introduce the notion of quasi-affine varieties.
If we have a set A1, say that has no non-zero functions with zeros at each of its points, then could we regard the function corresponding to the zero polynomial as having zeros at each of the points of A1 ... ... so that the set of functions {z} where z is the zero function is zero on all points of A1 ... and hence A1 qualifies as an affine algebraic set ... ..
Ah, but note that your "zero function" vanishes not only on $A_1$, but in all of $\Bbb A^n$. To prove that $A_1$ is affine, you have to find a set of functions $S$ which vanish only on $A_1$ - that is $A_1$ is the whole zero locus of the functions in $S$.
K
Mathbalarka,
Thanks for your very interesting and helpful post ...
I am now thinking and reflecting over what you have written ...
Thanks again,
Peter***EDIT***Can I just confirm something that I think you have said ...
I think you a saying that there are some subsets of affine space that are not algebraic sets ... is that correct?If it is correct can you specify some examples ...?
Yes, that is correct. I have given an example in my answer :
Hi Mathbalarka,
Indeed you did give such an example ... Thanks ...
Peter
