Calculating the Mass of a Piece of Glass Using Archimedes' Principle
The discussion focuses on calculating the mass of a piece of glass using Archimedes' Principle. A metal piece weighing 20 grams has an equal apparent weight to the glass when both are submerged in water. When the medium is changed to alcohol with a density of 0.96, an additional 0.84 grams is required to restore balance. The calculations involve understanding apparent weight changes based on fluid density and applying the principles of buoyancy to derive the mass of the glass piece.
  • Understanding of Archimedes' Principle
  • Basic knowledge of buoyancy and apparent weight
  • Familiarity with density calculations
  • Ability to manipulate algebraic equations
  • Study the derivation of Archimedes' Principle in detail
  • Learn about buoyant force calculations in different fluids
  • Explore density variations and their effects on apparent weight
  • Practice solving problems involving submerged objects in various liquids
Students studying physics, particularly those focusing on fluid mechanics and buoyancy, as well as educators looking for practical examples of Archimedes' Principle in action.
soumya_26in
1.a piece of metal of weight 20gms has equal apparent weight with a piece of glass when both are suspended from the arms of a balance and immersed in water(density 1).if water is replaced by alcohol(density 0.96), 0.84gms must be added to the pan from which the metal is suspended to restore balance.what is the mass of the glass piece?
2.a cube with each side of unit length has the same force F applied normally outwards on all its six faces.what are the expressions of longitudinal & volume strain in terms of the elastic modulii?
Welcome to PF!
Hi soumya! Welcome to PF! :smile:
You must tell us how far you've got, so that we know what's troubling you, and how to help.
Start with the balance … what have you tried?
What equations have you got? :smile:
actually both prblms were in my class eleven's final Q paper.i have tried 1) as follows:
1)let,
mass of the glass piece=m gms
In 1st case, apparent wt of metal=(20-20/d1),d1=density of the metal
& apparent wt of glass=(m-m/d2),d2=density of the glass
by the prblm,
20-20/d1=m-m/d2.....(i)
In case 2, apparent wt of metal=[20-(20+0.84)*0.96/d1]
& apparent wt of glass=(m-m*0.96/d2)
by the prblm,
[20-(20.84*0.96)/d1]=(m-m*0.96/d2)....(ii)
is this process write?
1)let,
by the prblm,
by the prblm,
No.
(You understand, I can't give you the answer, I can only help you do it yourself? So …)
20 is the mass of the metal, but d1 is the mass/volume of the water - so 20/d1 isn't anything.
Start again. Do it one step at a time.
First: what is Archimedes principle?
How exactly does it reduce the weight of the metal? What does it depend on? Are there any unknowns?
Same for the glass.
What equation can you write? :smile:
(How did you manage to post twice? :smile: If you click on "edit" under the second post, I think it gives you the option of deleting.)
  • · Replies 29 ·
11K
28K
