Dopplershift said:
In special relativity,
When an object travels at speeds near the speed of light, time slows down for the person on traveling at that speed, thus you gain more time. Also, you have length contraction.
So my question is this, with the idea of 4-dimesional space-time, is what you gain in time lost in length?
This picture is not a good one, but a conclusion like the one that you are after can be derived.
When an object travels at near the speed of light, time does not slow down. Nor does length contract. Clocks on the object tick away merrily at one second per second -- as compared with other clocks on the object. Meter sticks on the object are still one meter long -- as compared with other meter sticks on the object. All the usual rules of physics apply in their usual way. There is no way for the object to tell whether it is really moving at nearly the speed of light or whether it is standing still.
It is when you compare clocks mounted on the moving object against [sets of synchronized] clocks at rest in some reference frame that you could conclude that clocks on the moving object are running slow. Is is when you compare [synchronized positions of the ends of] meter sticks on the moving object against a meter stick in some reference frame that you can conclude that meter sticks on the moving object are shortened.
How rapidly a clock ticks and how long a meter stick is are both relative. They depend on what frame of reference you use to measure them against. Hence the name "relativity".
However, not all things are relative. Some things are "
invariant". An invariant quantity is one where you get the same result no matter what reference frame you use to perform your measurements. A place where you can find "trade-offs" is in the invariants.
One invariant is the length of a space-time interval. This is the separation between two "events". An event is a position in space at a particular time. It takes three coordinates of space (e.g. x, y and z) to specify the position and along with one coordinate of time (e.g. t). So you can specify an event with four coordinates. They won't be the same coordinates in every reference frame. But no matter what reference frame you use, there will be a set of coordinates for the event.
The length of a space time interval from (x
1, y
1, z
1, t
1) to (x
2, y
2, z
2, t
2) is computed as ##\sqrt{(x_1-x_2)^2 + (y_1-y_2)^2 + (z_1-z_2)^2 - (t_1-t_2)^2}##
Note the similarity the Pythagorean distance formula. This one is the same, except that there is a minus sign on the time coordinate.
It turns out that interval length is invariant. It does not matter what reference frame you use to measure the (x, y, z, t) coordinates for each event. The resulting computed interval length will be the same. If the distance offset between the endpoints increases and the time offset between the endpoints also increases, that is a trade-off that can make the length of the interval stay the same.
