Are my answers correct? (3D statics)
  • Thread starter Thread starter Femme_physics
    Statics
12 replies · 3K views
Femme_physics
I don't have the solution manual answer for this problem, can anyone help please confirm my answers are correct?
http://img860.imageshack.us/img860/6118/40893341.jpg [/QUOTE]
On a smooth horizontal weightless surface ABDC acts at the center a vertical force of 600 [N]. The surface is connected to the wall through axes A and B and supported by shaft CE.
A) Calculate reaction at CE
B) Calculate reactions at axes A and B. Presume the forces at the B axis are at the X and Y direction only.
This is my solution attempt
http://img204.imageshack.us/img204/2712/20112011a.jpg
http://img834.imageshack.us/img834/6539/20112011b.jpg ]
And here below in the thumbnail I have attached my friend's attempt. He's smart, but new to 3D statics, and I don't understand how what he did makes sense. In fact it contradicts my results and methods.
Femme_physics said:
I don't understand what your friend did.
It looks rather complex, but his answers are wrong.
I definitely prefer your method. :smile:
Reducing the problem to 2D makes it much easier to follow what you did.
However, you also made a mistake.
It starts with your zx-view, when you calculated TCEzx where you used TCEy, but you should have used TCEx.
Same for the calculation of TCEz.
As a consequence, your Bx, Ax, and Az are wrong too.
*smacks forehead*
I'll tell you why, I'm used to "y" being up so I keep confusing myself :-p
Thanks a bunch :smile: will correct it today
But "y" is up! :confused: :-p
I like Serena said:
But "y" is up!:confused: :-p
It's "up" in the 3D drawing. But in the 2D ones, it's always psychologically my "up"-- something which I still haven't completely gotten rid off.
Uhh, it's up in 3D and it's up in your yx-view and it's up in your yz-view. :rolleyes:
It's just that in 3D normally z is always up, and in the yz-view z should be up too! :smile:
Yes, I said psychologically "up" as in the sense that's it's pointing towards the upper part of the page that I'm writing on heh, I still haven't gotten over it is what am saying
Still, in this problem y is pointing up to the physical top of your page.
I think you've gotten over that just fine! :smile:
You're already used to the fact that z should be pointing up to the physical top of your page.
The challenge in this problem is to apply the direction of the y-coordinate mathematically, carefully without making assumptions based on the 3D you're already used to.
That really makes this problem harder than it has to be. :wink:
not if you're looking at the xz view
*smacks forehead*
Oooooooooooooooooooooooh!
(Thanks for clarifying that! :wink:)
Yay! :smile:
You didn't ask for it, but I give it the ILSe-stamp-of-approval.
Btw, whatever happened to that item that I didn't put a stamp-of-approval on? :blushing:
Maybe I didn't ask, but I secretly desired! :wink:
Thanks :mrgreen:
"Btw, whatever happened to that item that I didn't put a stamp-of-approval on?
To be amended, rest be assured! :smile:
