Are Some Real Numbers Countable and Others Uncountable?
  • Context: Undergrad
  • Thread starter Thread starter emptyboat
    Numbers Real numbers
The discussion revolves around the countability of real numbers versus natural numbers, exploring whether some real numbers can be considered countable while others are uncountable. Participants engage in theoretical reasoning, mathematical arguments, and counterexamples related to the concepts of countability and infinity.
  • Some participants argue that real numbers are countable, suggesting a one-to-one correspondence between natural numbers and real numbers in the interval (0,1).
  • Others assert that real numbers are uncountable, referencing Cantor's diagonal argument to demonstrate that any list of real numbers can be shown to be incomplete.
  • Several participants challenge the initial claim of countability by pointing out that the proposed correspondences only account for a limited subset of real numbers and fail to include irrational numbers.
  • There are claims that natural numbers are countably infinite, while real numbers are uncountably infinite, emphasizing the distinction between the two sets.
  • Some participants propose that the argument for countability relies on flawed assumptions and does not hold when considering all real numbers, particularly those greater than 1 or irrational numbers.
  • Counterexamples are presented, such as rational numbers, to illustrate the complexity of the countability argument and to question the validity of the proposed correspondences.
  • Participants express the need for rigorous proof to establish claims about the countability of decimals and their relationship to natural numbers.
Participants generally disagree on the countability of real numbers, with multiple competing views presented. Some maintain that real numbers are countable, while others firmly argue for their uncountability, leading to an unresolved discussion.
Limitations include the reliance on specific examples and assumptions about the nature of real numbers and their representation. The discussion highlights the complexity of defining countability and the potential for misunderstanding in the application of mathematical proofs.
emptyboat
I think that real number is countable. Because there is one to one correspondence from natural numbers to (0,1) real numbers.
0.1 - 1
0.2 - 2
0.3 - 3
0.21 - 12
0.123 - 321
0.1245 - 5421
I think that is a one-to-one corresepondence. Any errors here?
  • Sad
  • Skeptical
Yes. They are uncountable. Assume that your list contains all real numbers. Now add 1 to the first digit of the first number, add 1 to the second digit of the second number, 1 to the third digit of the third number, and so on. If you find a 9, then turn it into a zero.
The number you get, if you concatenate all changed digits is a number that was not in your list, i.e. whichever list you choose, there is a number that is not listed. Hence the real numbers are uncountable.
Your logic is like this.
1 - 1
2 - 2
3 - 3
10 - 10
11 - 11
123-123
Assume that this list contains all natural numbers. Now add 1 to the ones place of the first number.(1+1=2), add 1 to the tens place of the second number(0+1=1), add 1 to the hundreds place of the third number(0+1=1), and so on. (If you do it third times, you get 112.)
The number you get, if you concatenate all changed digits is a number that was not in your list, i.e. whichever list you choose, there is a number that is not listed. Hence the natural numbers are uncountable.
1 - 1
2 - 2
3 - 3
10 - 10
11 - 11
123-123
No. Natural numbers are not infinitely long. My argument goes like this:
0.168435 ...
0.899958 ...
0.915476 ...
0.153798 ...
turns into
0.268435 ...
0.809958 ...
0.916476 ...
0.153898 ...
If we have e.g. 0.5, then we write it as 0.5000000 ...
You cannot do this with natural numbers.
0.168435 ...
0.899958 ...
0.915476 ...
0.153798 ...
turns into
0.268435 ...
0.809958 ...
0.916476 ...
0.153898 ...
If I
turns into
1004
I can go on this process.
Natural numbers have the potential to be infinitely long.
Yes, the reals are infinite and the natural number are infinite. Up to this point you got it.
But naturals are countably infinite. The reals are uncountably infinite. Not the same.
I do not see where things got confused, but I think that @fresh_42 did not want to explicitly inflict Cantor's proof on you. I think he is using the proof in "example mode". He can correct me.
Further reading which I hope helps you:
https://en.wikipedia.org/wiki/Countable_set
0.1 - 1
0.2 - 2
0.3 - 3
0.21 - 12
0.123 - 321
0.1245 - 5421
All the numbers you listed have finite length and end in infinite 0's. At what point would you count 0.1212121212...?
And there are a lot more where that came from. I think that you can see that you have only counted a tiny, tiny subset of the real numbers.
EDIT: In fact, this method misses a lot of rational numbers, which are countable. 0.12121212.. = 12/99.
Besides the actual proofs that the reals are uncountable, it seems clear that your construction fails for real numbers greater than 1. I also don’t think it works for irrational numbers and maybe not even some rational numbers.
@fresh_42 left out the last step in the traditional diagonal argument:
0.168435 ...
0.899958 ...
0.915476 ...
0.153798 ...
turns into
0.268435 ...
0.809958 ...
0.916476 ...
0.153898 ...
After we have the second list:
0.268435 ...
0.809958 ...
0.916476 ...
0.153898 ...
we take the changed (bolded) numbers and make a new number (0.2068…) that wasn’t in the previous list. We know it wasn’t because if it were the nth number, its nth digit would be 1 less than it is.
It's very simple. (mirror refection with zero in center)
Every sigle-digit decimals correspond to every single-digit natural numbers(9 pieces).
(1-0.1, 2-0.2, 3-0.3, ..., 9-0.9)
Every two-digits decimals correspond to every two-digit natural numbers(90 pieces).
(10 - 0.01, 11 - 0.11, 12-0.21, ..., 97 - 0.79, 98 - 0.89, 99 - 0.99)
Every three-digits decimals correspond to every three-digit natural numbers(900 pieces).
(100 - 0.001, 101 - 0.101, 102 - 0.201, ..., 997 - 0.799, 998 - 0.899, 999 - 0.999)
And so on...
Every dicimals have countable digit decimals, aren't they?
If you let go of the mindset that Real numbers are uncountable, it's very simple and easy.
Aren't they?
Prove it.
TeethWhitener said:
Prove it.
If natural numbers have countable digits, and every dicimal also has countable digits.
(Because it's mirror refection with zero in center).
Natural numbers are countable and natural numbers are greater than digits of natural numbers, so digits of natural numbers are countable, and also every dicimal has countable digits.
What would you call ##12/99 = 0.1212121212...= 0.121212\overline{12}##? Are you going to ignore all the rational numbers like that?
You can’t just assert the part I asked you to prove and expect anyone to buy it. If you want to assert that every infinite string can be mapped to the reversed infinite string, then yes, you’ve just effectively shown that you can map the real numbers to the real numbers. But you have to put “every dicimal” in 1-1 correspondence with every natural number first. You’ve been given a number of counterexamples at this point. I suggest you study them with a little bit of seriousness.
12/99 is correspond to ...1212121212, but there is not such a natural number.
But I think if your logic is true, rational numbers are also uncountable.
In the case of rational numbers, countable means like that, it shows a possibility of one-to-one correspondence. But in the case of real numbers, the perspective changes.
pl;ace an interval of length 1/4 over the natural number 1. Then place an interval of length 1/8 over the natural number 2. then place an interval of length 1/16 over the natural number 3. ... continuing, you have covered the natural numbers by a sequence of intervals of length 1/2. but the unit interval [0,1] has length 1. contradiction.
No. It just shows that the natural numbers are not countable by your method. They are countable but your method is seriously flawed.
FactChecker said:
No. It just shows that the natural numbers are not countable by your method. They are countable but your method is grossly flawed.
Yes. I understand countable meaning and subtle difference between rational numbers and real numbers.
I pick a random rational number as 12/99 and if order can be given it's countable.
But if I pick π, I cannot give order to that number. So it's uncountable.
Thanks!
I think it is worthwhile to realize how easy it is to create irrational numbers. Just make sequences that never start repeating, like 0.101001000100001000000100000001000000001...
And for any such number, you can add it to a list of rational numbers to get a list of irrational numbers.
IMHO, that makes it easier to accept how the irrational numbers are such a huge set compared to the rationals (although it is not a proof by any means).
Cantor's proof is genius and is worth studying. Mathematicians of his time hated and resisted his conclusion that there are higher, uncountable, orders of infinity, but it was undeniable.
0.1 - 1
0.2 - 2
0.3 - 3
0.21 - 12
0.123 - 321
0.1245 - 5421
You list has only numbers with finite decimal expansions - not enough.
Not only are the reals uncountably infinite; also, any non-empty interval (open or closed) subset (no matter how small as long as it has non-zero extension) of ##\mathbb{R}## (the reals) that includes all of the reals that are within itself (inclusive or exclusive of boundaries) is also uncountably infinite.
And the set of all subsets of the real numbers are even more uncountable and so on...
I trust that you understand that 'uncountable' is a 'yes-or-no' condition, and that therefore nothing can possibly be "even more uncountable" than something else that is 'uncountable' is; however, I think that it's worth pointing out that even the infinitesimal is exactly as 'uncountably infinite' in its fractional expansion as the entirety of ##\mathbb{R}## (the reals) in its fractional expansions is (the concept of divisibility may be regarded as inconsistent with the concept of infinitesimality; i.e., it could be not unrightly said that the infinitesimal is not divisible, wherefore, there could be no 'fractional expansion' of the infinitesimal).
That reminds me of Russel's Paradox
The reals on [0,1] are easily countable, just paste them in Excel and click 'sort ascending'
  • Haha
sysprog said:
I trust that you understand that 'uncountable' is a 'yes-or-no' condition, and that therefore nothing can possibly be "even more uncountable" than something else that is 'uncountable' is; however, I think that it's worth pointing out that even the infinitesimal is exactly as 'uncountably infinite' in its fractional expansion as the entirety of ##\mathbb{R}## (the reals) in its is.
I think @Svein is referring to the fact that the power set of ##\mathbb{R}## has a greater cardinality than ##\mathbb{R}##.
I think that you're right about that; however, I trust that he understands that the greater cardinality does not increase its uncountability, which of course cannot increase beyond 'uncountable' any more than a switched-on light switch can be more 'on' than 'on'.
Is this correct?
The cardinality of an interval in R is proportional to its length, and as it is uncountable, the cardinality of some arbitrarily small nonzero interval in R is greater than all of N
BWV said:
Is this correct?
The cardinality of any non-empty interval of non-zero length in ##\mathbb{R}## is not proportional to its length; it's the same as that of the whole of ##\mathbb{R}## (and is therefore greater than that of ##\mathbb{N}##). Although the length of 1 inch on a 12-inch ruler is obviously less than that of the 12 inches of such a ruler, the cardinality of the unit interval ##[0,1]## is the same as that of the interval ##[0,12]##. The number of possible divisions is uncountably infinite in both cases. A discussion of matters fundamentally related to this can be found at https://plato.stanford.edu/entries/continuum-hypothesis/
Some jokes fall more than flat.
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 55 ·
9K
