- 9,554
- 4,792
When you check your pockets on leaving the house ##-## let's see, keys, wallet, phone, TI-83 (graphing calculator), ok, good to go ##-## is a too-flat ##-## hmm ##-## more than flat ##-## maybe a B♭ (B flat) clarinet that's more than too flat maybe an A♮ (A natural) clarion?Svein said:Some jokes fall more than flat.
BWV said:Is this correct?
The cardinality of an interval in R is proportional to its length, and as it is uncountable, the cardinality of some arbitrarily small nonzero interval in R is greater than all of N
PeroK said:Gazing up into the darkness I saw myself as a creature driven and derided by vanity; and my eyes burned with anguish and anger.
So do (0,1) and (0,12) in R have the same cardinality because a function exists to map them (multiply/divide by 12) or do, by definition, all uncountable sets have the same cardinality?stevendaryl said:No, that's not correct. The cardinality of an interval is not affected by its length. An interval of length 1 has the same cardinality as the full set of real numbers.
Two sets have the same cardinality if you can map one set to the other in a one-to-one fashion. The mapping:
##x \mapsto log(\frac{x}{1-x})##
maps any ##x## in the range ##(0,1)## to a real number in the range ##(-\infty, +\infty)##, showing that those two ranges have the same cardinality.
BWV said:So do (0,1) and (0,12) in R have the same cardinality because a function exists to map them (multiply/divide by 12) or do, by definition, all uncountable sets have the same cardinality?
by the above, do (0,1) and (0,12) in the rationals have the same cardinality?
dextercioby said:Is the cardinality of the powerset of ##\mathbb{R}## (or ##\mathbb{R}^n##, with ##n## finite) aleph_2?
If not, what is aleph_2?
This depends on whether your system accepts or rejects the continuum hypothesis. The cardinality of the natural numbers is ##\aleph_0## and the cardinality of the real numbers is ##2^{\aleph_0}##, but the continuum hypothesis (the assertion that ##2^{\aleph_0}=\aleph_1##) is independent of the axioms of ZFC.dextercioby said:Is the cardinality of the powerset of R (or Rn, with n finite) aleph_2?
This part is not right. There are higher cardinal numbers. There is a whole sequence of them of increasing size.BWV said:do, by definition, all uncountable sets have the same cardinality?
Just to pile on, Cantor's theorem is that, for any set ##A##, given its powerset ##\mathcal{P}(A)##--defined as the set of all subsets of ##A##--the cardinality of the powerset will always be strictly greater than the cardinality of the set: ##|\mathcal{P}(A)|>|A|##BWV said:do, by definition, all uncountable sets have the same cardinality?
What's the image of ##\pi##? Or any other Irrational?emptyboat said:Your logic is like this.
1 - 1
2 - 2
3 - 3
10 - 10
11 - 11
123-123
Assume that this list contains all natural numbers. Now add 1 to the ones place of the first number.(1+1=2), add 1 to the tens place of the second number(0+1=1), add 1 to the hundreds place of the third number(0+1=1), and so on. (If you do it third times, you get 112.)
The number you get, if you concatenate all changed digits is a number that was not in your list, i.e. whichever list you choose, there is a number that is not listed. Hence the natural numbers are uncountable.
Good point. It's true for every set, finite or infinite.sysprog said:Cantor proved that the power set of ##\mathbb{R}## has cardinality greater than that of ##\mathbb{R}##. The continuum hypothesis is that nothing has cardinality in between those. Please if you find such a thing, or can prove that there is no such thing, let us know.![]()
There is also measure theory which is probably more along the lines of your original intuition.BWV said:So do (0,1) and (0,12) in R have the same cardinality because a function exists to map them (multiply/divide by 12) or do, by definition, all uncountable sets have the same cardinality?
Jarvis323 said:There is also measure theory which is probably more along the lines of your original intuition.
Yes, two sets have the same cardinality iff there is a bijection between them.BWV said:So do (0,1) and (0,12) in R have the same cardinality because a function exists to map them (multiply/divide by 12) or do, by definition, all uncountable sets have the same cardinality?
That is of course true; however, it is clearly not true that "all uncountable sets have the same cardinality", ##-## e.g. ##|2^\mathbb{R}|>|\mathbb{R}|## (i.e., the cardinality of the power set of ##\mathbb{R}## is strictly greater than that of ##\mathbb{R}##), and both ##2^\mathbb{R}## and ##\mathbb{R}## are uncountable sets.WWGD said:BWV said:So do (0,1) and (0,12) in R have the same cardinality because a function exists to map them (multiply/divide by 12) or do, by definition, all uncountable sets have the same cardinality?
by the above, do (0,1) and (0,12) in the rationals have the same cardinality?WWGD said:Yes, two sets have the same cardinality iff there is a bijection between them.
I agree. The fact that for any set S ##|P(S)|>|S| ## proves this. And also proves there is no set of all sets. Its powerset would be of cardinality larger than it.sysprog said:That is of course true; however, it is clearly not true that "all uncountable sets have the same cardinality", ##-## e.g. ##|2^\mathbb{R}|>|\mathbb{R}|## (i.e., the cardinality of the power set of ##\mathbb{R}## is strictly greater than that of ##\mathbb{R}##), and both ##2^\mathbb{R}## and ##\mathbb{R}## are uncountable sets.
It depends if by ##\infty ## you mean ##| \mathbb N | ## or ##| \mathbb R | ##. First is ( or can be seen as; it's equivalent to ) the set of all sequences of Real numbers ( using ##A^B ## as the set of all maps from A to B ), second is the set of all functions from the Reals to itself ). If you see R as a metric space, first is metrizable, second one is not. Cardinalities are different. Maybe someone can double-check my set theory/infinite arithmetic, which is pretty rusty. Assuming continuum hypothesis , ## 2^{\aleph_0}=\aleph_1 ##. Then ##| |\mathbb R|^{|\mathbb N| } = 2^{ \aleph_0 \times \aleph_0}= 2^{\aleph_0^2}= 2^{ \aleph_0} ## while ## |\mathbb R|^{| \mathbb R| }= 2^{ \aleph_0 \times \aleph_1}= 2^{ \aleph_1}##dextercioby said:Is ##\mathbb{R}^{\infty}## properly defined (as infinity is properly understood in classical analysis)? If so, does it have the same cardinality as ##\mathbb{R}^{n}## for arbitrary but finite ##n##? What would be a proof of that?
Yes, but please wait for someone to double-check my arithmetic. I haven't done any in a really long time.dextercioby said:Yes, sorry, not fully explicit. The ##\infty## in my post is the cardinality of ##\mathbb N##. So you say that ##\left| \mathbb{R}^{|\mathbb{N}|}\right| = \aleph_1 \equiv |\mathbb{R}|##.
Looks ok to me, but I am also rusty on this, so consider it a fractional vote of confidence.WWGD said:Yes, but please wait for someone to double-check my arithmetic. I haven't done any in a really long time.
You don’t even need the continuum hypothesis, as ##|\mathbb{R}|=2^{|\mathbb{N}|}##. The rest of the math looks fine to me.WWGD said:It depends if by ##\infty ## you mean ##| \mathbb N | ## or ##| \mathbb R | ##. First is ( or can be seen as; it's equivalent to ) the set of all sequences of Real numbers ( using ##A^B ## as the set of all maps from A to B ), second is the set of all functions from the Reals to itself ). If you see R as a metric space, first is metrizable, second one is not. Cardinalities are different. Maybe someone can double-check my set theory/infinite arithmetic, which is pretty rusty. Assuming continuum hypothesis , ## 2^{\aleph_0}=\aleph_1 ##. Then ##| |\mathbb R|^{|\mathbb N| } = 2^{ \aleph_0 \times \aleph_0}= 2^{\aleph_0^2}= 2^{ \aleph_0} ## while ## |\mathbb R|^{| \mathbb R| }= 2^{ \aleph_0 \times \aleph_1}= 2^{ \aleph_1}##
Premises:FactChecker said:I think it is worthwhile to realize how easy it is to create irrational numbers. Just make sequences that never start repeating, like 0.101001000100001000000100000001000000001...
And for any such number, you can add it to a list of rational numbers to get a list of irrational numbers.
IMHO, that makes it easier to accept how the irrational numbers are such a huge set compared to the rationals (although it is not a proof by any means).
Cantor's proof is genius and is worth studying. Mathematicians of his time hated and resisted his conclusion that there are higher, uncountable, orders of infinity, but it was undeniable.
Correct. Sorry for delay in replying.dextercioby said:Yes, sorry, not fully explicit. The ##\infty## in my post is the cardinality of ##\mathbb N##. So you say that ##\left| \mathbb{R}^{|\mathbb{N}|}\right| = \aleph_1 \equiv |\mathbb{R}|##.
Can you justify the implicit assertion I have highlighted above? I do not even understand what it is saying.vortextor said:Premises:
The real numbers include all the rational numbers and all the irrational numbers.
An irrational number has a representation of infinite length that is not, from any point, an
indefinitely repeating sequence of finite length.
A rational number has a terminating sequence or has an indefinitely repeating sequence of finite length.
The set of rational numbers is countable, and the set of real numbers is uncountable.
My conclusion;
Since any irrational number can be transformed in an infinite set of rational numbers with
terminating sequence, the set of rational numbers must be more dense and uncountable ?
This is obviously invalid, however I can't see why?
But you can generate an infinite set of irrational numbers from an irrational number as well:vortextor said:Since any irrational number can be transformed in an infinite set of rational numbers with
I think he’s referring to the sequence ##\{3,3.1,3.14,3.141,\ldots\}## of rationals converging on the irrational ##\pi##. I could be wrong though.jbriggs444 said:Can you justify the implicit assertion I have highlighted above? I do not even understand what it is saying.
