Are the Current Directions and Poles Correct in These Electrical Diagrams?
  • Thread starter Thread starter Manaphy180
    Electrical
The discussion revolves around the correctness of current directions and magnetic poles in electrical diagrams, specifically focusing on two figures provided by the original poster. The subject area includes concepts from electromagnetism and circuit theory.
  • The original poster seeks validation of current directions and pole placements in their diagrams. Some participants reference the right-hand rule and discuss the flow of current in relation to magnetic poles. Others express uncertainty about the setup and the implications of the diagrams.
Participants are actively engaging with the questions posed, offering references and insights related to the right-hand rule and the nature of current flow. There is a mix of interpretations regarding the correctness of the diagrams, with some participants suggesting that the original poster's labeling may be accurate while others express doubt.
There are indications of confusion regarding the conventions of current flow (from positive to negative versus negative to positive) and the effects of the wire on the magnetic field. The original poster has added arrows to their diagrams, which has led to further questions about their meaning and correctness.
Manaphy180
Hi, I have two questions that I want to solve correctly... and help is a appreciated.
1. Is the current direction/Poles on right figure correct? https://www.dropbox.com/s/bs3lvak4wda5lqu/23.png
2. This one I'm sure is wrong... not too sure what I'm doing here... Are the currents correct at all? Poles, arrows were added by me https://www.dropbox.com/s/24iecu3bm6grlq7/25.png
Thanks in advance, If I could get insight or answers ASAP that would be great :D
jedishrfu said:
Check out this wiki article on the right hand rule and apply it to your problem:
http://en.wikipedia.org/wiki/Righthand_rule
midway down is the rules for current and north pole
You're right, I totally forgot about that, Thanks. Do you have any insight into the second question?
current goes from -ve to +ve
there s a rule for working out the force on a current carrying wire in a magnetic field.
Using the rule it appears that you've labeled the poles correctly. I am not sure about the cylinder thing. Are you trying to draw an electric motor schematic?
Sorry, I should have mentioned that it's a magnet with coil wrapped around it. Would the North to South Pole direction change?
Thanks guys, I suppose my real question is about the electromagnetic pole from the North to South pole that acts on the object between. Does it still go from North to South, or does the wire along the magnet interfere with that?
I think it still go from north to south, just like ordinary U shaped magnet...
So the diagram I drew for my 2nd question was correct? I really want to know that I'm doing this right before I get into it. Thanks
I just understand the electromagnet, I don't understand what is between the magnet in your picture sir..
As I know, magnetic field come from the north pole to the south pole...one direction, no way back
It shouldn't.
No, it's not correct.
What are all those arrows you've drawn on the wire?
NascentOxygen said:
It shouldn't.
I was answering another thread with a different diagram it seems.
Don't you just hate that, when you get cross-threaded? :wink:
There exist circuits where current goes from - to + ? Where can I find one?
Conventional current?
I don't think so
In that thread Simon was referring to.. :wink:
  • · Replies 40 ·
  • · Replies 28 ·
