Mentor
- 37,215
- 16,330
Ok, thanks, that is helpful. The term you are objecting to is the relativity of simultaneity. It is indeed the most challenging concept in special relativity and the one that most directly disagrees with student’s intuition and “common sense”. Nevertheless, nature is relativistic.Leepappas said:While the equation ##\Delta t'=\gamma \Delta t## was merely distasteful, the equation
$$\Delta t'= \gamma (\Delta t - v\Delta x)$$
Is totally repugnant.
In the former equation, ## \Delta t'## isn't a function of the coordinates of a point in the unprimed frame. In the latter equation ##\Delta t'## is a function of the coordinates of a point in the unprimed frame. That goes against all common sense.
What this term represents is not that the passage of time depends on location. It is that there is a location-dependent offset to synchronized clocks.
In other words, if you have synchronized two clocks in your frame then in my frame they are desynchronized by an amount given by that term. Both clocks tick at the same rate in my frame, but they are not synchronized in my frame despite being synchronized in yours.
