Are There Nontrivial Solutions to the Matrix Equation X C X^T = C?
  • Context: Undergrad
  • Thread starter Thread starter vibe3
    Matrix
The discussion revolves around finding nontrivial solutions to the matrix equation X C X^T = C, where C is defined as the outer product of a vector c. Participants explore the implications of this equation, its relation to the Sylvester equation, and the conditions under which solutions may exist.
  • Some participants note that X = I is a trivial solution, but they seek nontrivial solutions and suggest that assuming X is invertible might help.
  • There is a discussion about whether C can be treated as a scalar or a matrix, with some arguing that it is a rank one matrix.
  • One participant mentions that the problem is underdetermined and raises questions about the nature of the solutions being sought.
  • Another participant introduces the idea of singular value decomposition (SVD) of X and discusses the relationship between singular vectors of X and the structure of C.
  • There are mentions of constraints involving the trace operation and conditions under which the singular values of the decomposed matrix must equal one.
  • A later reply suggests a specific approach for constructing a legal X by manipulating the matrix representation of C.
Participants express differing views on the nature of C and the types of solutions available, indicating that multiple competing perspectives remain. The discussion does not reach a consensus on the existence or form of nontrivial solutions.
The problem is noted to be underdetermined, with various assumptions about the nature of C and the rank of matrices involved influencing the discussion. There are unresolved mathematical steps and dependencies on definitions that participants highlight.
vibe3
Hello, if I have some given vector [itex]c \in R^n[/itex], then I want to find solutions [itex]X \in R^{n\times n}[/itex] to the following equation:
[tex] X C X^T = C[/tex]
where [itex]C = c c^T[/itex]. Certainly [itex]X = I[/itex] is a solution, but I'm looking for any nontrivial solutions. We can also assume [itex]X[/itex] is invertible if that helps.
This equation seems related to the Sylvester equation. If the solution is nontrivial, I would appreciate if someone could point me in the direction of any work which has been done on this type of equation.
Assume you have chosen a basis such that ##c=(1,0,\ldots,0)^T##. How many solutions do you get?
Isn't C then a scalar? But then ## CXX^{T} ## is a matrix and C is a scalar. Am I missing something?
Depends on how you write vectors, as a column or as a row: one gives a scalar and the other a rank one matrix. Either case has many solutions.
But how can an ## n \times n ## matrix equal a ## 1 \times 1 ## unless n=1? EDIT: Do you mean we extend the scalar C into a matrix (C,0,0,..,0)?
You mean if ##C## is a scalar? Then ##XCX^T=C=CI## by the usual identification of the two ones in algebras with unit. Otherwise ##\begin{bmatrix}c_1\\ \vdots \\c_n\end{bmatrix} \cdot \begin{bmatrix}c_1 & \ldots & c_n \end{bmatrix}## is a ##n \times n## matrix of rank ##1##.
I mean, which case do you assume then, that C is ## n \times n ## or a "scalar matrix"?
C is an n-by-n matrix of rank 1
Thanks, kind of reminds me of least-square problems, solved by ortho projections.
It's not clear to me what kind of "solution" OP is looking for since this problem is very much underdetermined. There are some interesting underlying relations here between singular vectors of ##\mathbf X## and the structure of ##\mathbf C##, but that's about all I can add.
note: if ##\mathbf c = \mathbf 0##, any ##\mathbf X## is allowed.
Now assume ##\mathbf c \neq \mathbf 0##. Thus ##\mathbf C = \mathbf{cc}^T## is a rank one matrix.
We can do singular value decomposition on ##\mathbf X## such that ##\mathbf X = \mathbf{U \Sigma V}^T##
For ##\mathbf{X C X}^T = \mathbf{X c} \mathbf c^T \mathbf X^T= \mathbf{cc}^T##, we know that ##\mathbf c## is given by one (or more) of the right singular vectors of ##\mathbf X## that has a singular value of 1 ##^{**}##. Why? Using the trace operation we see
##trace\big(\mathbf{cc}^T\big) = \mathbf c ^T \mathbf c = trace\big(\mathbf{X c} \mathbf c^T \mathbf X^T\big) ##
##\mathbf c ^T \mathbf c = trace\big(\mathbf{X c} \mathbf c^T \mathbf X^T\big) = trace\big(\mathbf c^T \mathbf X^T \mathbf{Xc}\big) = \mathbf c^T \mathbf X^T \mathbf{Xc} = \mathbf c^T \mathbf V \mathbf \Sigma^T \mathbf U^T \mathbf {U \Sigma V}^T \mathbf c = \mathbf c^T \mathbf V \mathbf{\Sigma}^2 \mathbf{V}^T \mathbf c = \mathbf y^T \mathbf{\Sigma}^2 \mathbf{y} = \mathbf y^T \mathbf y##
where ##\mathbf{V}^T \mathbf c := \mathbf y##, and of course ##\big \Vert \mathbf c \big \Vert_2^2 = \big \Vert \mathbf{V}^T \mathbf c \big \Vert_2^2 = \big \Vert \mathbf y \big \Vert_2^2##
##^{**}## to be more accurate: it is possible that that the squared singular values that non-zero elements of ##\mathbf y## gets scaled by are not one-- the exact constraint we need to observe is
## \mathbf y^T \mathbf{\Sigma}^2 \mathbf{y} = \sigma_1 ^2 y_1^2 + \sigma_2^2 y_2^2 +... + \sigma_n ^2 y_n^2 = y_1^2 + y_2^2 +... + y_n^2 =\mathbf y^T \mathbf y##
There's also a lot of flexibility in determining ##\mathbf U##. If ##\mathbf X## is full rank, you can also tease out the constraint that, ##\mathbf c ^T \mathbf c = \mathbf c^T \mathbf U \mathbf{\Sigma}^{-2} \mathbf{U}^T \mathbf c = \mathbf w^T \mathbf{\Sigma}^{-2} \mathbf w = \mathbf w^T \mathbf w##, where ##\mathbf{U}^T \mathbf c := \mathbf w##.
Losing some generality, here's one particularly easy approach for creating a legal ##\mathbf X##: write out ##\mathbf C = \mathbf {PDP}^T##, where ##\mathbf D## is the zero matrix except the top left entry is given by ##trace\big(\mathbf C\big)##. From here ensure that all values of ##y_k = 0## for ##k \geq 2##, and that ##\sigma_1 = 1##, then set ##\mathbf U := \mathbf P##.
Again, this whole thing is a very much underdetermined problem so there's a lot of different ways to approach this.
  • · Replies 33 ·
  • · Replies 23 ·
