Are these permissible ways of writing Mandelbrot's Equation?
  • Thread starter Thread starter emergentecon
    Mandelbrot Writing
Mandelbrot's equation is correctly expressed as z -> z^2 + c, which denotes an iteration rather than an equation. Alternative forms like z = z^2 + c or f(z) = z^2 + c do not accurately represent the iterative process intended by Mandelbrot. The notation z = z^2 + c only holds true for specific values of z, while f(z) treats z as a variable, diverging from Mandelbrot's use of z as a specific test point. Although some sources may use f(z) in discussions about the Mandelbrot set, this can lead to confusion if not properly contextualized. It is essential to adhere to conventional definitions in mathematical discussions to avoid misinterpretation.
emergentecon
When asked about his work, Mandelbrot wrote his equation as such: z -> z^2 + c
Is it permissible to also write it as:
z = z^2 + c
and / or
f(z) = z^2 + c
Mathematics news on Phys.org
No - well, you can if you really want to but neither of them is correct in that the relations do not describe the same process.
##z\to z^2+c: z,c\in\mathbb C## refers to an iteration. Notice that it is not an equation. Equations have an "=" sign.
You could write ##z_{n+1}=z_{n}^2+c## to relate the next term in the iteration with the previous one ... but it kinda misses the point.
Think: what is the purpose of the iterations?
##z=z^2+c## would only evaluate true for one or two values of z - think what the "=" sign means.
##f(z)=z^2+c## would be treating z as a variable when, crucially, Mandelbrot's ##z## is a specific test point.
The idea is to test it to see if it is a member of the set.
Likes emergentecon
Simon Bridge said:
No - well, you can if you really want to but neither of them is correct in that they relations do not describe the same process.
Ok thank you very much for the explanation . . .
Because they really really want to? Maybe they left something out or are just abusing the notation - its quite a chatty page.
Lets see - reading - they are not actually using ##f(z)=z^2+c## as an equivalent to writing ##z\to z^2+c##.
They are basically putting: ##z\to f(z)## or ##z_{n+1}=f(z_n)## ... that use is implicit in the context. When you use f(z) like this it is called a "map".
Likes emergentecon
For instance, from here: http://mathworld.wolfram.com/MandelbrotSet.html
The term Mandelbrot set can also be applied to generalizations of "the" Mandelbrot set in which the function
is replaced by some other function. In the above plot, [PLAIN]http://mathworld.wolfram.com/images/equations/MandelbrotSet/Inline92.gif, [PLAIN]http://mathworld.wolfram.com/images/equations/MandelbrotSet/Inline93.gif, and http://mathworld.wolfram.com/images/equations/MandelbrotSet/Inline94.gif is allowed to vary in the complex plane. Note that completely different sets (that are not Mandelbrot sets) can be obtained for choices of
that do not lie in the fractal attractor. So, for example, in the above set, picking
inside the unit disk but outside the red basins gives a set of completely different-looking images.
So the function which generates the mandelbrot set, is the function
iterated over complex numbers?
True, and in fact, they refer to it as a map from what I see . . .
... same with the mathworld one.
Don't worry, look hard enough and you will find someone with some kind of authority making the error.
That does not make it correct - it just makes them being unconventional (at best) or wrong (at worst).
Make sure you also read and understand the su
In general:
You can if you really really want to...
You can use any definitions you like, but if you depart from the conventions, you have to explain your definitions in the accompanying text.
You can say: Let = be the addition operator and + be the equality; then 1=1+2 would be a valid mathematical statement evaluating "true".
As the Old Man of the Mountain was known to say: "Everything is permissible."
