MHB Can These Mathematical Sets Be Considered Subspaces?
  • Thread starter Thread starter mathmari
    Sets Subspaces
The discussion centers on determining whether specific mathematical sets are subspaces of vector spaces. The sets analyzed include \(U_1\), defined as \(\{(x, y) \mid x^2 + y^2 \leq 4\}\), which is not a subspace; \(U_2\), defined as \(\{(2a, -a) \mid a \in \mathbb{R}\}\), which is a subspace; \(U_3\), defined as \(\{(x, y, z) \mid y = 0\}\), which is a subspace; and \(U_4\), defined as \(\{(x, y, z) \mid y = 1\}\), which is not a subspace. The key criteria for a set to be a subspace include containing the zero vector and being closed under vector addition and scalar multiplication.
  • Understanding of vector spaces and subspaces
  • Familiarity with linear algebra concepts, particularly vector addition and scalar multiplication
  • Knowledge of the definitions of mathematical sets in \(\mathbb{R}^2\) and \(\mathbb{R}^3\)
  • Ability to analyze geometric representations of sets
  • Study the properties of vector spaces and subspaces in linear algebra
  • Learn about the criteria for a set to be a subspace, including closure under addition and scalar multiplication
  • Explore examples of subspaces in \(\mathbb{R}^2\) and \(\mathbb{R}^3\)
  • Investigate the implications of the zero vector in determining subspaces
Students and educators in mathematics, particularly those studying linear algebra, as well as anyone interested in understanding the properties of vector spaces and subspaces.
mathmari
MHB
Hey! :o
We have the following subsets:
\begin{align*}&U_1:=\left \{\begin{pmatrix}x \\ y\end{pmatrix} \mid x^2+y^2\leq 4\right \} \subseteq \mathbb{R}^2\\ &U_2:=\left \{\begin{pmatrix}2a \\ -a\end{pmatrix} \mid a\in \mathbb{R}\right \} \subseteq \mathbb{R}^2 \\ &U_3:=\left \{\begin{pmatrix}x \\ y \\ z\end{pmatrix} \mid y=0\right \}\subseteq \mathbb{R}^3 \\ &U_4:=\left \{\begin{pmatrix}x \\ y \\ z\end{pmatrix} \mid y=1\right \}\subseteq \mathbb{R}^3\end{align*}
I want to sketch these sets and check in that way if these are subspaces. We have the following graphs:
  • $U_1$ :
    [DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-5,"ymin":-5.5,"xmax":5,"ymax":5.5}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"x^{2\\ }+y^2\\ \\le\\ 4"}]}}[/DESMOS]
    This is a subspace, isn't it? But how can we explain that from the graph? (Wondering)
  • $U_2$ :
    [DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-10,"ymin":-5.5,"xmax":10,"ymax":5.5}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"x=-2y"}]}}[/DESMOS]
    Since this line goes through the origin, it is a subspace, or not? (Wondering)
  • This is the $xz$ plane with $y=0$.
    This is a subspace, since the zero vector is contained, or not? (Wondering)
  • This is the $xz$ plane with $y=1$.
    This is not a subspace since the zero vector is not contained. Is that correct? (Wondering)
mathmari said:
Hey! :o
  • $U_1$ :
  • $U_2$ :
Your graph for the first one looks odd because your graph does not have the same size units on the two axes. The graph should be a circle, not an ellipse. As for "subspace", are you clear on what a subspace is? If u and v are in the space then u+ v and au, for a any number, must be in the space.
For the first one, u= (2, 0) is in the space but 2(2, 0)= (4, 0) is not.
For the second one we can write u= (2a, -a) and v= (2b, -b). Then u+ v= (2a+ 2b, -a- b)= (2(a+ b), -(a+ b)) so is also in the set. And for any number, x, x(2a, -a)= (2(xa), -(xa)) so is in the set. Yes, the origin, (0, 0)= (2(0), -0) is in the set. Geometrically a subspace of R2 is a line through the origin. The first example was not a line.
Yes, the third is the xz-plane. In R3, any subspace is either a line containing the origin or a plane containing the origin. This is a plane containing the origin. A proof that this is a subspace would be to take two such vectors as u= (a, 0, b) and v= (c, 0, d). Then u+ v= (a+c, 0, b+ d) which is in the set and, for x any number, xu= (xa, 0, xb), in the set.
Strictly speaking the last one is NOT "the xz-plane with y= 1". The "xz-plane" always has y= 0. This is a plane parallel to the xz-plane. You are right that this is not a subspace because it does not contain the origin. More specifically, u= (a, 1, b) is in the set but 2u= (2a, 2, 2b) is not.
You seem to be under that impression that a set is a subspace as long as it contains the origin. That is "necessary" condition, but is not "sufficient". A subspace of R2 must be a line containing the origin and a subspace of R3 must be a line or plane containing the origin.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 34 ·
