Are virtual particles real or just math filler
81 replies · 15K views
Orodruin said:
I do not understand your desire to interpret more into the virtual particles than there is to it.
I'm not trying to interpret more than there is to it. I'm trying to understand what is to it. I don't understand how you could have missed my point. It seems obvious and unavoidable that we need to understand what's inside the integrals just as we do in classical mechanics. If some of that involves virtual effects then we need to understand that as well.
We may be using the term "virtual" in different ways. You seem to be using them to refer only to terms in a perturbation expansion. I think I may be using them more generally as mathematical artifacts that exist everywhere and must be taken account of in calculations. I don't think your use of virtual particles in a perturbation expansion take into account other uses of virtual in such things as the Casimir effect, that assume they are all over the place and not just hiding in a the calculation of some particular observable.
friend said:
What do these exponentials of differential Actions mean if not virtual particles?
It is a fallacy that each part of a formula means something else than what the formula actually says.
Orodruin said:
the Feynman rules, including the virtual particles, are only a means of keeping track of the terms in this series. This does not change the fact that the path integral itself is well defined without virtual particles.
Yes. The path integral is (in certain cases) well-defined, but as you say, the virtual particles are only a means of keeping track of the terms in this series. They don't have more meaning in the path integral itself than the terms ##x^n/n!## in the expansion of the exponential function have for the exponential function itself! They even have less meaning since most individual Feynman diagrams evaluate to infinity if taken by themselves, and only well-chosen combinations in the formal expansion lead to a well-defined numerical result.
friend said:
we don't question what the integrand means in those classical integrals, and we feel that the integrand in those classical integrals do have intuitive physical meaning.
We also don't question what the integrand means in a path integral, and the integrand in a path integral does have intuitive physical meaning. But once you are singling out particular contributions to the path integral appearing in a perturbative expansion and declare them to have physical meaning by themselves it is like saying that ##x^n/n!## has an intrinsic meaning for the exponential function. But the exponential function can be defined in many other ways, e.g., as the limit ##\lim_{n\to\infty}(1+x/n)^n##, where these terms are completely absent - so they cannot have an intrinsic meaning. Similarly, the path integral can be defined in other ways, e.g., as a formal limit of lattice approximations, and if you do that, virtual particles are completely absent - so they cannot have an intrinsic meaning.
But I won't argue that again; read and think about the link in post #4 of this thread! If after having digested that you still want to argue, you are incurable and I won't answer anymore.
Those are some interesting points. But if virtual particles are a way of understanding processes in some calculations, then the bottom line is that if they can lead to calculations, then use them. That's what they do in the Casimir effect, isn't it? I'm not arguing that they are necessarily real. I'm perfectly content to say that they are mathematical artifacts. For we haven't proven that our mathematical description of physics is unique, have we? There might be other math that results in the same answers. So perhaps we should start showing the math we are referring to and stop arguing about undefined words. (What is a virtual particle? Sheeeesh)
It is precisely the same use, once you look at the calculations done.
Only how one talks about them may differ from application to application and from author to author since virtual particles as ''real'' objects (rather than wiggles on paper) are limited in their properties only by the fantasy of the respective authors.
They don't lead to calculations. They are a pictorial way to talk about calculations without having to display the details. And they are indeed heavily used in this way. Just don't mistake this use as being more than figurative speech!
friend said:
I feel like I'm arguing the existence of God, something that is the cause of everything else but not in and of itself observable. What is it, then, that we are integrating in the path integral? The integrand in the path integral is the exponential of the complex Action integral. And this exponential of the Action can be broken up into exponentials of differential Actions. What do these exponentials of differential Actions mean if not virtual particles?
When you do a Fourier analysis on a function and express the function as an integral what does that function mean? That too is integrating over complex exponentials. Does that mean it contains virtual particles that are real?
Thanks
Bill
If you want to that you must study a textbook.
Thanks
Bill
One should, however, stress that the Casimir effect is (of course) NOT proof of the existence of "vacuum fluctuations" but of quantum mechanical charge and em.-field fluctuations. Without any matter there's no Casimir effect. The usually treated way in introductory textbooks describing two conducting plates in terms of a boundary-value problem is in fact the em. coupling to ##\infty## limit (leading to an ideal conductor as an idealized model for the plates) of the true affairs. See
http://arxiv.org/abs/hep-th/0503158
vanhees71 said:
Without having read the paper, I can only say that for sure they don't measure the vacuum. The very fact that they measure something means that there is a measurement apparatus present, and that's not vacuum. There are quantum fluctuations of the electromagnetic field, but they manifest themselves always only at the presence of charges, because we cannot detect anything without having the interaction of the electromagnetic field with matter consituting a measurement device, and this matter consists of electrically charged particles.
They used electro-optic sampling with following setup: Electro-optic sampling of an electric-field waveform by an ultrafast probe pulse, consisting of an EOX (electro-optical crystal), a quarter-wave plate (λ/4), a Wollaston polarizer (WP), and a differential photocurrent detector (DD).
Obviously you have a point. What perplexes me is how can this research be titled as it is? The only way to understand it is umm... 'We tuned into the void to see what the fabric of reality itself translates into when looked at with an optical kaleidoscope?'
Well, I must admit that I couldn't understand the paper just from reading, because I'm not an expert in quantum-optics. At least they could have written out their three-letter acronyms. I'd have to dig through a lot of literature before being perhaps able to do so.
Obviously the referee was not very strict in letter through this paper in the published form! I don't say that there's anything wrong with the core physics, but despite the misleading title at least the introduction, I'd have rejected right away, because neither of the given examples for radiation correction effects of QED are "vacuum fluctuations". Rather they are indeed quantum fluctuations of charges and the em. field: There's no Casimir effect without charges (google for Jaffe and Casimir effect to find a nice treatment). The Lambshift of the hydrogen lines are quantum effects on the Coulomb-bound state energies (vertex corrections, photon polarization, including also QCD corrections) etc. etc.
Thinking again about the math of virtual particles. They are supposed to come in pairs, but together they don't result in anything permanent. What kind of math would do that? What kind of math leads to complete annihilation or cancellation for two particles that both start at the same point at the same time and both end at the same different point at the same time? Presumably they are described by some sort of amplitude with a magnitude and phase. So I don't think you'd multiply the two amplitudes because even if you got the phases to cancel, you can't get the magnitude to equal zero. So I think we're talking about adding the amplitudes in superposition to try to get cancellation. But even here you can't have one being the complex conjugate of the other because that does not guarantee that the two vectors/amplitudes are 180° out of phase in order to cancel. Is there some way to make sure the two amplitudes are 180° out of phase even though they start at the same place at the same time and end at a different place at the same time?
Obviously math you do not understand.
Its simply terms in what's called a Dyson series:
https://en.wikipedia.org/wiki/Dyson_series
Your continual harping on about it will not change anything and simply leads to posts that repeat the same thing over and over.
Thanks
Bill
Is there a paper explaining Hawking Radiation without succumbing to virtual particles similar to Jaffe's paper on the Casimir Effect? Unfortunately, Gravitation by MTW (the only GR textbook I have) doesn't cover hawking radiation and a cursory glance at google all mention pair-creation.
Or, if there is a specifcally good textbook treatment of it, I'd appreciate it.
friend said:
Thinking again about the math of virtual particles. They are supposed to come in pairs, but together they don't result in anything permanent. What kind of math would do that? What kind of math leads to complete annihilation or cancellation for two particles that both start at the same point at the same time and both end at the same different point at the same time? ...
The transition amplitude for a particle to go from |x> to |x'> is
[tex]< x'|U(t)|x > \,\,\, = \,\,\,{\left( {\frac{m}{{2\pi \hbar it}}} \right)^{{\raise0.5ex\hbox{$\scriptstyle 1$}<br /> \kern-0.1em/\kern-0.15em<br /> \lower0.25ex\hbox{$\scriptstyle 2$}}}}{e^{im{{(x' - x)}^2}/2\hbar t}}.[/tex]
I take this as true even for a virtual particle. The antiparticle is said to travel backwards in time between the same two points. So its transition amplitude would be
[tex]< x|U(t)|x' > \,\,\, = \,\,\,{\left( {\frac{{ - m}}{{2\pi \hbar it}}} \right)^{{\raise0.5ex\hbox{$\scriptstyle 1$}<br /> \kern-0.1em/\kern-0.15em<br /> \lower0.25ex\hbox{$\scriptstyle 2$}}}}{e^{ - im{{(x - x')}^2}/2\hbar t}}[/tex]
by simply replacing t with -t. (Or take the complex conjugate). Yes, you can argue that these transitions are not measurable at these specific points since the |x> basis is a continuous spectrum. Granted! But bear with me because I'm trying to prove just that. I'm just considering the transition from some generic point to another generic point for a virtual particle pair that is said to go from some point to another.
The minus sign comes out of the square-root as the complex number i. So, we get
[tex]< x|U(t)|x' > \,\,\, = \,\,\,i{\left( {\frac{m}{{2\pi \hbar it}}} \right)^{{\raise0.5ex\hbox{$\scriptstyle 1$}<br /> \kern-0.1em/\kern-0.15em<br /> \lower0.25ex\hbox{$\scriptstyle 2$}}}}{e^{ - im{{(x - x')}^2}/2\hbar t}}[/tex]
This is not a transition from one point by a particle and then back again by the antiparticle. The two transitions happen at the same time. And a real particle might interact with one or the other, and we can't say which. So we can consider these two virtual particles to be in superposition with each other. And then the expectation value for measuring these particles would be
[tex]| < x'|U(t)|x > {|^2}\,\, + \,\,\,| < x|U(t)|x' > {|^2}[/tex]
As seen from the above, the only difference between these terms is the complex number i in the antiparticle. After squaring it the only difference would be a minus sign, and the sum would be zero. This is what we are told, that they exist as wave functions but have zero expectation value of ever being measured. So you could fill space with as many virtual particle pairs as you like, even infinitely many, and it would not be noticeable by any observer.
Did I get my math right?
Since virtual particles are not real why you assume that beats me.
Yes some your math is correct but you are atrociously mixing concepts.
That's utter nonsense.
You need to study an actual textbook.
Thanks
Bill
If virtual particles exist at all, then they have a wave function that guides the way they transition from place to place.
I've heard professors say that space itself is made of virtual particles. And I've come to understand this in my own way. So if a particle propagates it must be through this sea of virtual particles (=space). If virtual particles have the same kind of transition amplitudes as those found in the propagator, then this provides a method of propagation through that sea. The propagation proceeds as follows: There already exists virtual particle pairs everywhere, including near a real particle. If a virtual particle-antiparticle pair appears near a real particle, then the real particle can annihilate with the antiparticle of the virtual pair. This leaves real the virtual particle that did not annihilate with its original partner. Thus the real particle use the transition amplitude of the virtual particle to jump from one position to the next. And now that the "real-ness" has been handed off to the virtual particle that did not annihilate, it is now subject to another jump by annihilating with yet another virtual pair, and so on through the path normally described with the path integral. If there is no expectation whatsoever of ever observing a virtual particle pair, then this is as good an interpretation of what's going on in the path integral as any other. If we accepted virtual particles to begin with, then maybe that would have led to the path integral formulation much sooner. Who knows what other properties can be described with them.
This is a pretty safe comment. No speculation there. And you're not even saying I'm wrong.
That's always a good idea. All in all, you've not said anything, though a bit snarky on your part.
I've looked, and I've not seen any books that go into a lot of detail about the math of virtual particles. It's disturbing that just about every professor in the classroom as well as the popular stage uses virtual particles to describe what's going on. But non of them go into depth into the math. Maybe that's what you're frustrated with.
Why are you starting with a falsehood? And that is not what a wave-function is.
friend said:
I've looked, and I've not seen any books that go into a lot of detail about the math of virtual particles. .
This does:
https://www.amazon.com/dp/019969933X/?tag=pfamazon01-20
friend said:
IIt's disturbing that just about every professor in the classroom
A number of professors post here and they don't.
This is my last post to you in this thread. Go away and study a textbook.
Thanks
Bill
Honestly, I doubt I'm going to find what I'm looking for in a textbook, though it may help. I'm looking into foundational issues, why QM is the way it is? What logic justifies QM to begin with. However, most textbooks give a record of the history of its development. And the math they use seems to be used only because it works. But in my opinion, that does not explain why it is the way it is. It only describes that it is that way and what the implication of that are to application.
This is generally a bad thing to do without any guidance. You will come out on the other side with several misunderstandings, such as the ones you have displayed in this thread and in the rest of the quoted paragraph.
Then you have not looked very well. Essentially any introductory text on quantum field theory will cover this and the mathematics is rather straight forward given the required previous knowledge.
This is also wrong. You will see professionals use this kind of language in popular science and perhaps in courses which do not go very deep into the underlying quantum field theory aspects. Through popular science and survey courses you will learn about science, you will not learn science.
This is the only reason to use anything in an empirical science. People who know QFT know what they are talking about when they mention virtual particles and they know how they enter into the mathematics. Just because you cannot figure it out on your own does not mean it is not already known.
With that said, I believe it is time to close this thread. The original question has been answered several times over.
