Area between a line and a parabola
The discussion focuses on finding the area enclosed by the line y = x - 1 and the parabola y² = 2x + 6. The intersection points are identified as (-1, -2) and (5, 4). The initial approach using vertical strips and incorrect integrands led to confusion with long decimal results. The correct method involves using horizontal strips, which simplifies the integration process by requiring two separate integrals to account for the different boundaries of the region.
  • Understanding of integral calculus, specifically definite integrals
  • Familiarity with the concepts of area under curves
  • Knowledge of graphing functions, particularly parabolas and linear equations
  • Experience with u-substitution in integration
  • Learn how to set up integrals for areas between curves using horizontal strips
  • Study the method of using u-substitution in definite integrals
  • Explore the graphical interpretation of integrals to visualize areas between curves
  • Practice solving similar problems involving areas between different types of functions
Students studying calculus, particularly those focusing on integration techniques and area calculations between curves. This discussion is beneficial for anyone looking to improve their understanding of definite integrals and graphical methods in calculus.
VWhitehawk
Find the area enclosed by the line y = x-1 and the parabola y^2 = 2x+6
I don't think there are any special formulas or anything
Well, I graphed the two given equations as √2x+6 and x-1 and got intersects at point (-1,-2) and (5,4).
A = ∫(√2x+6) - (-√2x+6)dx
A = 2∫(√2x+6)dx
then I used u substitution to get 2/3u^(3/2). I turned the u back to 2x+6 and then solved it for the limits -2 and -1 (Solved 2/3(2x+6)^3/2))
but then the numbers get weird and become really long decimals...which I doubt I should be getting. Where did I go wrong? :(
Welcome to PF!
Hi VWhitehawk! Welcome to PF! :wink:
Have you tried looking at it sideways, and integrating wrt y instead of x ? :smile:
A = 2∫(√2x+6)dx
Your integrand is incorrect. The left boundary is the parabola, and the right boundary is the line, which you seem to have neglected. If you use horizontal strips, you can use one integral, but if you use vertical strips (as you have done), you need two separate integrals.
Oh, so the it should look like "∫((√2x+6) - (x-1))dx to take the line into account?
Not sure what you mean by doing it vertically, but from the way you say it, it sounds easier than doing it the horizontal way! lol
Here you are using vertical strips of width Δx. This won't work, since some strips run between the upper and lower parts of the parabola, while other strips run between the upper part of the parabola and the line. Since the strips are different, you need two different integrals.
Have you actually sketched a graph of the region?
Horizontal strips is width Δy are much simpler.
I have drawn it and the little rectangle too. I flipped the drawing sideways like you said but I just don't get what is supposed to be my integrand.
What little rectangle?
And what do you mean when you say you flipped the drawing sideways? tiny-tim was suggesting that you use horizontal strips, not that you turn the drawing sideways.
  • · Replies 20 ·
  • · Replies 105 ·
