Optimizing Work in a Parabolic Water Tank: Finding the Area of Cross-Sections
  • Thread starter Thread starter 7yler
    Area
The discussion focuses on optimizing work in a parabolic water tank defined by the equation y = x² for 0 ≤ y ≤ 4. The tank has a depth of 4 feet, a width of 4 feet, and a length of 5 feet. The work required to pump water to a height of 6 feet is calculated using the integral W = ∫_2^4 62.5(6-y)(4-y²)dy. Participants clarify that while the term (6-y) is correct for the height, the expression (4-y²) requires reevaluation for accuracy in determining the area of cross-sections.
  • Understanding of calculus, specifically integration techniques.
  • Familiarity with the concept of iterated integrals.
  • Knowledge of the geometry of parabolic shapes.
  • Basic principles of physics related to work and fluid dynamics.
  • Review the derivation of the area of cross-sections for parabolic shapes.
  • Study the application of iterated integrals in calculating work done in fluid mechanics.
  • Learn about the physical implications of pumping fluids against gravity.
  • Explore advanced integration techniques for complex shapes and volumes.
Students and professionals in mathematics, physics, and engineering fields, particularly those involved in fluid dynamics and optimization problems related to work and energy calculations.
7yler
The ends of a "parabolic" water tank are the shape of the region inside the graph of y = x^{2} for 0 ≤ y ≤ 4; the cross sections parallel to the top of the tank (and the ground) are rectangles. At its center the tank is 4 feet deep and 4 feet across. It is 5 feet long. Rain has filled the tank and water is removed by pumping it up to a pipe 2 feet above the top of the tank. Set up an iterated integral to find the work W that is done to lower the water to a depth of 2 feet and then find the work. [Hint: You will need to integrate with respect to y.]
So I came up with \int_2^4 62.5(6-y)(4-y^{2})dy , and I'm not sure why this integral isn't correct. The water is being pumped to 6 feet, so it's 6-y, right?
hi 7yle! :wink:
your (6 - y) is correct, but I have no idea what your (4 - y2) is supposed to be :confused:
your slice is 5 ft long, dy high, and … wide? :smile:
9K
  • · Replies 56 ·
