What Is the Common Difference in This Arithmetic Progression?
The discussion revolves around solving for the common difference, d, in a finite arithmetic progression where the sum, S_n, increases under specific conditions. Initially, the problem states that increasing d by 2 results in S_n tripling, while increasing d by 4 results in S_n quintupling. Participants initially struggled with the interpretation of the problem, leading to incorrect conclusions, such as a1 equaling zero. After clarifying the problem statement, the correct value for d was determined to be 4/3. The conversation highlights the importance of precise problem interpretation in mathematical solutions.
kaspis245
A finite arithmetic progression is given such that ##S_n>0## and ##d>0##. If the first member of the progression remains the same but ##d## increases by 2, then ##S_n## increases 3 times. If the first member of the progression remains the same but ##d## increases 4 times, then ##S_n## increases 5 times. Find ##d##.
##S_n=\frac{2a_1+d(n-1)}{2}\cdot n##
##\frac{2a_1+2d(n-1)}{2}\cdot n=\frac{2a_1+d(n-1)}{2}\cdot n \cdot 3##
##\frac{2a_1+4d(n-1)}{2}\cdot n=\frac{2a_1+d(n-1)}{2}\cdot n \cdot 5##
When I try to solve this I get ##a_1=0## which is clearly not possible. Can somebody explain me what am I doing wrong?
kaspis245 said:
A finite arithmetic progression is given such that ##S_n>0## and ##d>0##. If the first member of the progression remains the same but ##d## increases 2 times, then ##S_n## increases 3 times. If the first member of the progression remains the same but ##d## increases 4 times, then ##S_n## increases 5 times. Find ##d##.
I also find ##a_1=0##.
Are you sure about the way you interpret the exercise?
Maybe it should be: "If ##d## is increased by 2, then ##S_n## is multiplied by 3", and similarly for the second one.
Sorry for the confusion. I've updated my problem statement. The first part of the problem is: "If the first member of the progression remains the same but ##d## increases by 2, then ##S_n## increases 3 times." Everything else is the same.
Now I got ##d=\frac{4}{3}##.
So do I.
