Understanding Arrhenius Plots: ln(rate) vs 1/T for Determining Activation Energy
  • Thread starter Thread starter pwnzorz
    Arrhenius Plot
Arrhenius plots are commonly used to determine activation energy in chemical reactions, typically plotting ln(k) against 1/T. However, some discussions highlight that ln(rate) can also be plotted against 1/T to find activation energy, particularly in heterogeneous catalysis. This raises questions about the terminology, as the rate constant (k) is often referred to simply as "rate." The confusion stems from the fact that the Arrhenius equation, k=A*exp(-Ea/(R*T), applies to the rate constant, not the reaction rate itself. For the equation to hold, the rate must not be constant, suggesting that the use of "rate" in this context may lead to misunderstandings.
pwnzorz
I have been noticing that in some cases that Arrhenius plots are sometimes plotted ln(rate) vs 1/T as opposed to ln(k) vs 1/T to find activation energy especially in hetereogeneous catalysis.
Isn't the Arrhenius law k=A*exp(-Ea/(R*T))? why can ln(rate) also be plotted vs T^-1 to find activation energy?
Is it possible that some people refer to the rate constant simply as "rate?" Otherwise, the rate would have to be constant for the equation to apply.
Chet
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
  • · Replies 131 ·
9K
