MHB ASK: Time for Alan & Brian to Paint House Together?
  • Thread starter Thread starter Monoxdifly
    Paint
Alan, Brian, and Chester are tasked with painting a house together, with each having different individual completion times that exceed the time taken when they work collectively. The time it takes for all three to paint the house together is denoted as t, with Alan taking t+1 hours, Brian t+5 hours, and Chester t+8 hours to complete the job alone. The discussion involves deriving a cubic equation from the rates of work and ultimately leads to a quadratic equation for further analysis. The calculated time for Alan and Brian to paint the house together is approximately 1.82 hours. The problem originated from another forum, highlighting the collaborative nature of problem-solving in mathematics.
Monoxdifly
MHB
3 friends, Alan, Brian and Chester, paint a house. If Alan had to paint it on his own, it would take him one hour more than the time it would take for all three to paint it together. If Brian had to paint it on his own, it would take him five hours more than the time it would take for all three to paint it together, and Chester 8 hours more.
How much time would it take for Alan and Brian to paint it together?
Would it be like this?
$$\frac1{A+1}=\frac1A+\frac1B+\frac1C$$?
Will it have something to do with quadratic equation?
Mathematics news on Phys.org
Actually, the solution I came up with involved both a cubic & quadratic equation. There may be some clever, short solution, but I was unable to reason one out.
let $t$ be the number of hours it takes for all three painters to complete the job.
$\dfrac{1}{t+1} + \dfrac{1}{t+5} + \dfrac{1}{t+8} = \dfrac{1}{t}$
working this equation yielded the cubic equation
$t^3+7t^2-20=0$
using the rational root theorem resulted in the factorization
$(t+2)(t^2+5t-10)=0$
solving the quadratic factor yielded $t=\dfrac{-5+\sqrt{65}}{2} \approx 1.53 \text{ hrs}$, the time required to complete the job with all three working.
for just A and B ...
$\dfrac{1}{t+1}+\dfrac{1}{t+5} = \dfrac{1}{x}$, where $x$ is the time to complete the job with just A and B working.
Being lazy, I used my calculator ... $x \approx 1.82 \text{ hrs}$
Just curious, where did you get this problem?
From another forum. I though it looked simple enough, so I saved it in case I needed it. Turned out I couldn't solve it, so I tried to retrace from which forum it was from, but Google search showed no result. Thanks for your help, though. :)
Since you havn't said what "A", "B", and "C" represent it is impossible to say whether that equation is correct or not!
I will presume that "A" is the time, in hours, it would take Alan to do the job alone, that "B" is the time, in hours, it would take Brian to do the job alone, and that "C" is the time, in hours, it would take Chester to do the job alone. The rate at which each works will be 1 "job" divided by the time it takesto do job. Alan works at the rate of [math]\frac{1}{A}[/math] job/hour, Brian works at the rate of [math]\frac{1}{B}[/math] job/hour, and Chester works at the rate of [math]\frac{1}{C}[/math] job/hour.
When people work together their rates add. Working together, their rate will be [math]\frac{1}{A}+ \frac{1}{B}+ \frac{1}{C}=\frac{BC+AC+ AB}{ABC}[/math] job/hour and the time it would take for all three to do the job working together is
[math]\frac{1}{\frac{BC+ AC+ AB}{ABC}}= \frac{ABC}{BC+ AC+ AB}[/math]
So [math]A= \frac{ABC}{BC+AC+AB}+ 1[/math].
So [math]B= \frac{ABC}{BC+AC+AB}+ 5[/math].
So [math]C= \frac{ABC}{BC+AC+AB}+ 8[/math].
Solve those three equations for A, B, and C.
Since this has been here since January and I just can't leave it undone:
We have the three equations
$A= \frac{ABC}{AB+ AC+ BC}+ 1$
$B= \frac{ABC}{AB+ AC+ BC}+ 5$
$C= \frac{ABC}{AB+ AC+ BC}+ 8$
We can write those as
$A- 1= \frac{ABC}{AB+ AC+ BC}$
$B- 5= \frac{ABC}{AB+ AC+ BC}$ and
$C- 8= \frac{ABC}{AB+ AC+ BC}$
So A- 1= B- 5= C- 8
From A- 1= B- 5, A= B- 4.
From B- 5= C- 8, C= B+ 3.
So we can write $B- 5= \frac{ABC}{AB+ AC+ BC}$ as
$B- 5= \frac{B(B- 4)(B+3)}{B(B- 4)+ (B- 4)(B+ 3)+ B(B+ 3)}$.
$(B-5)B(B- 4)+ (B-5)(B+4)(B+3)+ (B-5)B(B+ 3)= B(B- 4)(B+3)$.
Multiply that out and each side will have a term of $B^3$ which will cancel leaving a quadratic equation to solve for B.
Good morning I have been refreshing my memory about Leibniz differentiation of integrals and found some useful videos from digital-university.org on YouTube. Although the audio quality is poor and the speaker proceeds a bit slowly, the explanations and processes are clear. However, it seems that one video in the Leibniz rule series is missing. While the videos are still present on YouTube, the referring website no longer exists but is preserved on the internet archive...
  • · Replies 25 ·
  • · Replies 35 ·
