Associated Legendre Function with Angles
8 replies · 2K views · last reply
bryanso
In Associated Legendre Function with Angles ... why is the following argument used?
## \sqrt{1 - x^2} = sin\,\theta ##
In Wikipedia https://en.m.wikipedia.org/wiki/Associated_Legendre_polynomials, Section Reparameterization in terms of angles, I see this argument:
Let ## x = cos\,\theta ##
This is also in Griffiths' Introduction to Quantum Mechanics.
Why is this a valid argument?
The LHS is always positive. The RHS is sometimes positive and sometimes negative. ##\theta = -1## makes it wrong.
Yes, one has to manage the range of the angels. For ##\theta > \pi## we need the negative root. I assume that most applications have angels from ##[0,\pi]## and in the other case: switch to the opposite orientation of the coordinate system. The problem only occurs if angels occur in both ranges.
bryanso said:
Homework Statement:: In Associated Legendre Function with Angles ... why is the following argument used?
Relevant Equations:: ## \sqrt{(1 - x)^2} = sin\,\theta ##
No, that's not what it says. Instead, it's ##\sqrt{1 - x^2}##. This is a standard substitution used in trig substitution in integrals.
You also have the same incorrect equation in your Relevant Equations.
It's better to manage the range of the angles. I don't think we'd have much luck trying to manage angels.
Yes I had a typo. I will try to edit it. The question remains.
Thanks. I have edited the equations.
The range of ##\theta## in spherical coordinates (which is where the associated Legendre functions are used) is 0 to ##\pi##. Therefore ##\sin(\theta)## is always positive.
Put differently, the domain of the associated Legendre functions (just as that of the Legendre polynomials) is [-1,1]. This is why ##x = \cos\theta## works so well with ##\theta \in [0,\pi]## (and, consequently, ##\sin\theta \geq 0##).
