Associated vs. Non-associated Laguerre Polynomials
terp.asessed
Could someone pls clarify if the value of x changes from just Laguerre polynomial to associated one? I am confused about the role of variable x.
From what I have learned in the class, I understand that L1n(x) = d/dx Ln(x), n = 1, 2, 3...
Because L1(x) = 1 - x and L2(x) = 2 - 4x + x2
I did:
L11(x) = d/dx L1(x) = d/dx (1 - x) = -1
L12(x) = d/dx L2(x) = d/dx (2-4x+x2) = 2x - 4 = 2(x - 2)...I wonder if x is a different function of radius in L11(x) (as in 1s orbital) and L12(x) (as in 2s orbital)? I am assuming the orbital polynomial on the basis of node...as in:
L11(x)= 1 because of 0 nodes...hence 1s
L12(x) = 2x -4 because of 1 node...hence 2s
Yes. The associated Laguerre polynomial found in hydrogenic wave functions is expressed as
L_{n+l}^{2l+1}(\rho)
with
\rho \equiv \frac{2 Z}{n a} r
where ##n## the principal quantum number and ##l## the angular momentum quantum number. You see that ##n## enters as a scaling factor in the argument of the associated Laguerre polynomial. Note also that the association between ##n## and ##l## and the associated Laguerre polynomial is a bit more complicated than your simple assumption based on the number of nodes, as angular nodes have to be considered also.
