At what time do the two balls hit each other?
  • Thread starter Thread starter sankalpmittal
    Kinematics Rocket
28 replies · 15K views
sankalpmittal
A rocket is moving in a gravity free space with a constant acceleration of 2 m/s2 along + x direction (see figure). The length of a chamber inside the rocket is 4 m. A ball is thrown from the left end of the chamber in + x direction with a speed of 0.3 m/s relative to the rocket. At the same time, another ball is thrown in -x direction with a speed of 0.2 m/s from its right end relative to the rocket. The time in seconds when the two balls hit each other is ?
Image: http://postimg.org/image/fh9trs9r5/
The answer ranges from 0 to 9.
http://en.wikipedia.org/wiki/Relative_velocity
Here is what I did.
If rocket accelerates by 2 m/s2 in +x direction, then balls inside it also accelerates with it with same value and in same direction in ground frame. Thus when we switch to frame of the rocket there is no acceleration on balls. Inside that frame I impose the concept of relative velocity and convert this two body problem to one body.
Velocity of left ball relative to right ball = 0.5 m/s in +x direction.
Thus time taken to collide = distance/Velocity of left ball relative to right ball = 4/0.5=8 seconds.
This is the correct answer.
However exam in which this question was asked says that both 8 seconds and 2 seconds answers are acceptable.
One book offers solution as :
Maximum displacement of the left ball from the left wall of the chamber is 2.25 cm, so the right ball has to travel almost the whole length of the chamber (4m) to hit the left ball. So the time taken by the right ball is 1.9 sec (approximately 2 sec).
Now my doubt is as follows :
How is 2 seconds a correct answer ? Also how can there be "two" values of time of collision ?
Please help !
Thanks in advance... :)
How do you know that? If the ball is thrown from one end, then why should it accelerate along with the rocket?
Observe from ground frame yourself.
See, if you are sitting in an accelerated train suppose, and you throw a ball vertically, it comes back to your hand right ? This is because it is accelerated with the train.
Waiting for someone else to reply though.
I know that. I actually forgot about the "relative" word in your question
No problem.
Just waiting for someone to reply and help me. xD
It's confusing question.. :confused:
I think I am going to have to refute that. As long as the ball is in your hand while you are on the accelerated train, then yes it is accelerating, but as soon as you throw it what forces are acting on it? None. The train keeps accelerating due to some force, but the ball being in air is subject only to its initial velocity and g with respect to the ground, no? If the train is going at a constant velocity, then the relative velocity is zero, yet if the trian is accelerating with acceleration [itex]\hat{a}[/itex], then the balls acceleration relative to the train is [itex]-\hat{a}[/itex].
EDIT: Remember: [itex]\hat{a}_{\text{1,2}} = \hat{a}_{\text{1,g}} - \hat{a}_{\text{2,g}}[/itex]
sankalpmittal said:
No problem.
This problem can be solved for either the rocket frame of reference or for the fixed frame of reference. Both approaches will give the same answer. Which frame do you prefer?
Chet
Chet
Hello Chet ! :)
I would like to solve the problem with both approaches. First I will do rocket frame approach. But do you not think I already solved it in my attempt at solution using rocket frame ? :confused:
In the rocket frame of reference, the system behaves as if there is a gravitational acceleration of 2 m/s2 in the negative x-direction. So, for the ball thrown from the left end at x = 0, the ball's location at time t is xl = 0.3t - t2. For the ball thrown from the right end at x = 4, its location at time t is xr=4 -0.2t - t^2. The balls meet when xl=xr.
time left ball right ball
0 0 4
1 -0.7 2.8
2 -3.4 -0.4
3 -8.1 -5.6
4 -14.8 -12.8
etc.
These results make no sense. Are you sure about that acceleration? Could it be 0.2 m/s2? With this acceleration, the left ball falls back to the left wall in a very short time.
Chet
The left ball falls back to the left wall every 0.3 seconds, and it never gets further from the wall than 0.0225 m, even if it bounces elastically. So the question really boils down to how long it takes for the right ball to fall to ~ 0.
Chet
Hi Sankalp
Nice question :)
This approach is not correct because as a result of collision of the left ball with the left wall of the rocket ,the velocity of the left ball changes after every 0.3 seconds (assuming elastic collision) .
I think 8 seconds cannot be the correct answer .OTOH approx. 2 seconds looks alright.
NO.
It is true if the train travels with constant velocity.
In an accelerating train, the released ball moves backward. Just like you if you stand and do not grab something fixed.
ehild
Tanya Sharma said:
Hi Sankalp
Nice question :)
Very good!
ehild
Thanks to all. :)
I think I figured it out.
From the rocket frame we have acceleration of 2 m/s2 in -x direction on each ball.
So maximum displacement traveled by left ball is u2/2a = 0.025 m.
Note that acceleration is still acting on left ball in -x direction.
Time taken :
0=0.3-2t
t=0.15 s.
In this time:
Distance by right ball :
-s=-0.2t-t2
s= 0.05 m.
Now 0.08 + 0.05 <<4
The right ball has to traverse a distance of 4-x, where x<0.02..
Hence approximating 4-x≈4 we have
-4=-0.2t-t2
This gives t=1.9 s ≈ 2 s...
Thanks to Chet.. His third post explains the reason for this theoretically.
Now why exam accepted 8 s ?
That's my reasoning :
If the balls are "kept on the floor of rocket cabin", then they have the same acceleration as rocket. Hence from rocket frame there is no acceleration on balls. Inside that frame I impose the concept of relative velocity and convert this two body problem to one body.
So both answers are correct.
Correct ?
ehild said:
Very good!
ehild
Thanks :smile:
I haven't been able to follow your reasoning.
Correct ?
That is still the same situation as in OP .Keeping the balls on the floor cabin do not give the balls same acceleration as that of rocket.
I think there is only one correct answer and that is 2 seconds.
Time taken :
0.025 = 0.3t-t2
This gives imaginary roots of t.. That means ... I approximate 0.025 ≈ 0.02..
0.02 = 0.3t-t2
What is 0.02 on the LHS ?
Why ? When you are sitting in the train, you are accelerated with the train. When you throw the ball up, then that acceleration doesn't count with it.
I can't say that 8 s cannot be the answer.
0.02 is the distance traversed by the left ball when it velocity becomes zero due to deceleration.
OK.
Assuming frictionless surface ,balls motion would be independent of the motion of the rocket .
In the train example ,when the person throws the ball up ,the acceleration of the ball will still be 9.8ms-2 . But if you are working from the train reference then surely you need to take into account the pseudo force .
But accounting for pseudo force is not the same thing as if the ball is having horizontal acceleration of the train in addition to its vertical gravitational acceleration.
If 2 sec is the correct answer ,what does 8 seconds signify ?
Tanya Sharma said:
OK.
More to the point.
8 s should signify that the right ball is taking approx. 6 seconds to move from left to right and then again left.
It has already taken 2 s to move from right to left initially.
Assume that left ball is fixed at x=0 for the sake of approximation.
Correct ?
sankalpmittal said:
More to the point.
Correct ?
Have you calculated the time it takes for the right ball to move from left to right end ,and left again ?
Does it come out to be 6 sec ?
I am curious to know what makes you so sure that 8 seconds is the correct answer :smile: .The answer key may be wrong .Which book are you referring to ?
Nope :(
Actually it comes out to be 3 seconds and the final answer as 3+2=5 seconds :(
Now why is 5 s not the answer ?
BTW, this question was asked in IIT-JEE advanced 2014.
See there are two possibilities-
i)Collisions between the ball and the rocket don't occur (the rocket is assumed to be very long or whatever)
In this case the answer is found very easily to be 8 sec. (Just see the relative speeds of the balls and divide them by the distance between them)
ii)Collisions occur (seems more reasonable when we look at the figure)
This raises further questions. Specifically, what is the coefficient of restitution for the collision? Since this information isn't given, we cannot proceed further.
So the question is incorrect.
sankalpmittal said:
Nope :(
2 seconds is the correct answer . Wherever 8 seconds is published ,it is surely done hastily assuming that the left ball doesn't collide with the left wall ,which is an incorrect assumption.
It is implicit that the question asks for the time when the two balls collide for the first time and you agree that it is 2 seconds .Why should you be concerned about the time when they collide for the second or third or nth time ?
Actually it is published by IIT itself at www.jeeadv.iitd.ac.in. See it yourself. :)
If they would have said minimum time taken for collision I would have agreed without questioning that it is 2 seconds and nothing more than that.
Nope. It is a 3 body problem. If you see from rocket frame you are bringing rocket "virtually" to rest and this imposes acceleration of 2 m/s2 on each of the ball in -x direction.
You can do nothing more than that. You seem to be thinking that we find relative velocity of one ball w.r.t another. Albeit, that doesn't mean that you ignore acceleration of rocket.
You can't convert this 3 body problem to one body.
Well you are right here but everyone will assume perfect elastic collision. I hope you have given this paper.
Awaiting more replies. Please help. :(
Probably the reason they accepted 8 seconds on the exam was that they felt that the students did not have time to reason it out in detail correctly. So they gave them a break. But, as Tanya pointed out, the only real correct answer is ≈ 2 sec.
Chet
The acceleration of the rocket doesn't matter when collisions aren't assumed to happen. Just see one ball w.r.t. the other. Answer is 8 sec only.
You can solve it from the rocket frame if you like, you will get the same answer.
Well well. I did get 8 seconds from both the frames only if rocket is infinitely long. But then I have my apprehensions :
1. The question specifically stated that the chamber length between two balls is 4 m.
2. The question was so framed that even a gauche would have implicitly assumed that collision has to occur.
So how in the world had they (the paper setters) stated that 8 seconds is also the correct answer ?
There has to be some way..
Maybe someone else will feel free to chip in.. :smile: He/she may enlighten me or... I have to confess that question created by IIT is wrong. -_- Heck :P
Anyone else ?
Only when the balls are fixed to the floor would they move with the same acceleration as the rocket. But then they do not move with respect to the rocket, and never meet.
The 8 s is a possible solution if the back wall of the rocket opens after the first ball leaves it.
The ball travels forward, but decelerates with respect to the rocket. Its relative velocity becomes zero, and then it starts to move backwards. If the wall is no more present it goes on backwards just like the other ball which overcomes it in 8 s.
ehild
ehild
Thanks ehild ! :)
I expected that. Although the question stated that chamber length is 4 m, none would have though of assuming that the wall of rocket chamber is absent.
Anyway comments and views shall be greatly acknowledged. Thanks to all once again!
