At which angles is the tension in a pendulum string maximized and halved?
  • Thread starter Thread starter 3ephemeralwnd
    Pendulum Physics
3 replies · 2K views
3ephemeralwnd
there is a pendulum with mass m, attached to the end of a string, oscillating back and forth between angles of -45 degrees and +45 degrees relative to the vertical axis
at which point would the tension be a maximum?
and at what 2 angles would the tension in the string be half of its maximum value?
Attempt:
i think the tension in the string is at maximum when the pendulum is at the very bottom, or when the angle is 0, because T = Fg at this point. (whereas everywhere else, the tension would only equal to the parallel component of the gravitational force, Fg(y))
so then i derived a formula for tension T = mgcos(theta)
if Tmax = mg , then half of the maximum tension must be 0.5 mg, correct?
So then, 0.5 mg = mg cos(theta)
0.5 = cos(theta)
and theta = 60 degrees
but i don't think that answer is correct because the range of angles according to the question is only between -45 and 45 degrees
any thoughts?
hi 3ephemeralwnd! :smile:
you have to do F = ma …
what is "a" ?​
Fnet = fg(x)
ma = mgsin(theta)
a = gsin(theta) ?
