What Is the Atomic Equivalent of the Wood-Saxon Potential?
  • Thread starter Thread starter BRN
    Atomic Potential
The Wood-Saxon potential is primarily used in nuclear physics to describe the nucleus, and the discussion seeks an analogous potential for atomic systems. It is clarified that a single atom does not have a potential in the same way a nucleus does. The conversation suggests that if the focus is on the electrons in an atom, quantum defect theory may serve as a relevant analogy. The inquiry highlights the need for a potential that applies specifically to single atoms rather than molecular interactions. The discussion concludes that understanding atomic potentials requires different theoretical frameworks compared to nuclear potentials.
BRN
Hi at all!
This is not a homework or simila, so I'm sorry if I post my question in a wrong section, but I do not know where to post it.
In the nuclear case, the Wood-Saxon potential is the main empirical potential used to describe the nucleus.
What would be the analogue in the atomic case?
The potentials of Morse and Lennard-Jons are related to the molecules, I would need one relative to the single atom.
Thanks!
I'm not sure what you are after. A single atom doesn't have a potential. Are you looking for a potential for the electrons in an atom?
If it is the latter you are after, the closest thing I can think of would be something like quantum defect theory.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
