Atwood Lab Homework: Analyze, Experiment & Report
  • Thread starter Thread starter o0griff0o
    Atwood Lab
3 replies · 3K views
o0griff0o
So I have this lab and I have no idea how to come about doing this.
An Atwood machine consisting of two massless pulleys (one smart pulley without friction and one pulley with friction) and hanging masses will be provided, as shown in the diagram below. you will be given specific quantities to solve for experimentally, using the Atwood machine.
Analyze the Atwood machine system shown and understand all of the physics involved. I will have only a few minutes in class to discuss the experimental problem and the technique to be used with your group, a few minutes to collect appropriate data with your group, and enough time to analyze your data individually and submit a short report. Good experimental technique will receive more points.
http://i601.photobucket.com/albums/tt92/…
F= ma T= I(alpha) Inertia for a disk = 1/2 MR^2
Umm I was thinking either to split this up into a net torque or a F=ma type of thing, but I was wondering how can a Pulley that is mass less have friction? Also Any ideas in gernal on how to go about with this lab?
ok so I set up torque equations at different points starting from right to left of the diagram.
starting at mass M1
1) T4-m1g=m1a
At the pulley connected to M1
2)-T4(r) + T3 (r) = (1/2 Mr^2)(a/r)
At the second pulley
3) -T2(r)+T1(r) = (1/2 Mr^2)(a/r)
then at m2
T1-m2g = m2a
Now The question says that there is friction so how would i incorparate that into equation 2?
Also I saw that the picture link was no working so here is another link to it http://i601.photobucket.com/albums/tt92/o0griff0o/atwoodmachine.png
Can I also assume that the acceleration throughout the whole system is equal?
Presumably the string is "light and inextensible", so that the linear acceleration should be everywhere the same assuming that the string remains taught.
Regarding the friction, it will behave as a torque on the pulley so you can model it as such. You should be able to fill in the details for it once you have them.
Also, if the pulleys really are massless as stated, then you might want to consider the implications for your equations involving their moments of inertia!
