Atwood System - max. height of the lighter object
The discussion centers on calculating the maximum height reached by the lighter mass in an Atwood system, where m1 = 1.71 kg and m2 = 4.59 kg. The acceleration of the system is determined to be 4.48 m/s², and the velocity of the lighter mass when the heavier mass hits the ground is calculated to be 4.83 m/s upwards. The key to solving the problem lies in understanding the "launch speed" of the lighter mass and applying kinematic equations to find the maximum height it reaches after being released from the pulley, which is 10.00 m above the ground.
  • Understanding of Atwood's machine dynamics
  • Familiarity with kinematic equations
  • Knowledge of gravitational acceleration (g = 9.81 N/kg)
  • Ability to perform calculations involving mass and acceleration
  • Learn how to apply kinematic equations to projectile motion
  • Study the principles of energy conservation in Atwood machines
  • Explore the concept of launch speed in vertical motion scenarios
  • Investigate the effects of pulley height on the dynamics of Atwood systems
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to clarify concepts related to Atwood machines and projectile motion.
laurs
The two masses are each initially 2.60 m above the ground, and the massless frictionless pulley is 10.00 m above the ground. The masses are m1 = 1.71 kg and m2 = 4.59 kg. What maximum height does the lighter object reach after the system is released?
(Hint: First determine the acceleration of the lighter mass and then its velocity at the moment the heavier one hits the ground.
This is its "launch" speed. Assume it doesn't hit the pulley.)
a = (m2-m1)(g)/(m2+m1)
vf^2 = vi^2 + 2ad
Fnet = ma
Fg = mg
Magnitude of acceleration of system:
a = (4.59kg - 1.71kg)(9.81N/kg)/(4.59kg + 1.71kg)
= 4.48 m/s^2
Velocity of lighter mass when heavier one hits the ground:
vf^2 = vi^2 + 2ad
= 0 + 2(4.48m/s^2)(2.60m)
vf = 4.83 m/s [up]
I am not sure what to do from here? I don't really understand what the hint means by launch speed, like is the mass flying out of the pulley into a parabolic trajectory?
laurs said:
Homework Statement: The two masses are each initially 2.60 m above the ground, and the massless frictionless pulley is 10.00 m above the ground. The masses are m1 = 1.71 kg and m2 = 4.59 kg. What maximum height does the lighter object reach after the system is released?
Homework Equations: a = (m2-m1)(g)/(m2+m1)
vf^2 = vi^2 + 2ad
Fnet = ma
Fg = mg
= 4.48 m/s^2
vf^2 = vi^2 + 2ad
vf = 4.83 m/s [up]
Hello, @laurs .
:welcome:
It's helpful to include all information in the body of your post, even if it's also included in thread's title.
Many of us are familiar with Atwood's machine. (Atwood system as you refer to it.) However, the point at which you are puzzled, indicates that you may not be familiar with it.
Is this the case?
Hi @SammyS
I am familiar with the machine, however am not accustomed to seeing questions asking for the height of the lighter weight. Most of the questions ask about the acceleration or the forces acting on the weights, which is a simple calculation, but I don't really know how to approach this one. I have been able to calculate time as well, assuming initial speed is 0, using the vf = vi + at, getting a value of t = 1.077s, but still am unsure how to approach the projectile portion of the question.
laurs said:
Hi @SammyS
As for the point you're stuck on:
The direction of "launch" is vertically upward at a distance of 5.20 m above the ground. The pulley is not involved. It's 10.00 m above the ground.
If an object is launched vertically with some initial speed, how high above the launch point will it get before it begins descending?
  • · Replies 19 ·
16K
